Fjäråskupan cooking hood app - for testing
Have been looking for a Homey app for Fjäråskupan cooker hoods for a while without luck. So, with the help of vibe coding I made an app my self. I am not a developer, and this is my first app for Homey, so please do not expect to much. Somehow, it does work for me.
The app allows turning on and off the light and set the level of the fan. Some Flowcards are included. I experience some delay when controlling the fan from the app, so some work has to be done there.
Feel free to test it out using this link: Fjäråskupan | Homey
Whenever I feel confident it is working for others than me, I will publish in the app store.
Any suggestions, bug reports or comments are welcome!
Quick update on the Fjäråskupan app.
Since my first post I have more or less rewritten the app, still with a lot of help from AI. The fan is now the main control of the device, and the light has its own on/off switch with dimming. You can choose between all six fan speeds, and there is support for periodic venting, after cooking, and the grease and carbon filter alarms. The filter alarms can be reset from the device’s maintenance settings. Changes you make with the buttons on the hood should now show up in Homey within a minute or so.
The delay I mentioned last time should be a lot better. The app keeps the Bluetooth connection open for a short while after a command, so several changes in a row go through quickly, and then lets go so the hood can report its status again. There are also quite a few new Flow cards, for example “Fan speed changed”, “Light is on” and “Turn off fan and light”.
The new version is available for testing here: Fjäråskupan | Homey
I am planning to submit it to the App Store soon, so I would really appreciate it if some of you could try it first. I only have one hood to test with, so I am especially interested in hearing from anyone with a different model. Does periodic venting turn off as it should, and do all the fan speeds match your hood? The source code is now on GitHub, GitHub - KalleSven/homey-fjaraskupan: App for Athom Homey for connecting Fjäråskupan coocking hood over bluetooth · GitHub , where you are also welcome to report bugs.
As before, suggestions, bug reports and comments are very welcome.
