Hi everyone,
today I present my second app: Libre CGM.
If you have a libre CGM aka Constant Glucose Monitor, you might be interested to have it available in homey. Here is your chance now.
Requirements:
- Libre CGM sensor (obviously)
- Libre Link UP account
- Sensor shared via Libre Link UP
Add as a device, login and choose the person to track. Thats it. You will have a device available with all infos the sensor offers via the api from libre LinkUp.
Use at own risk!
This app is not officially supported by Abbot. It was build with the work of others. If Abbot changes their API for the LibreLinkUp app this integration will most likely fail.
Also: I can not take any responsibility of cases of failure. This app is only with informational character and does not serve medical purposes! You are responsible for tracking your health.
Here the link for the app in testing: Libre CGM | Homey
I hereby proudly anounce: The app is Live!
Libre CGM sounds like a great integration—bringing glucose monitoring data directly into Homey makes tracking much easier. Simple setup via Libre Link UP and sensor sharing means users can quickly access all CGM info in one place.
Exactly and with the Insights feature of homey you can see how the glucose was over night without opening the libre app on the phone. Plus you have all the automation and warning features of homey which makes it a nice thing to have.
But there is a catch: This integration is relying on LinkUp and a working internet connection between homey and LibreLinkUp and the API of LibreLinkUp. So the posibility to warn of low glucose levels heavily relies on these factors. If Abbot decides to change their API the integration will likely stop to work. If the internet connection fails it is the same problem.
Hello Florain,
Thank you for the application, would it be possible in the future to integrate a dashboard widget for integration, a bit like in the native application on mobile, graphic, medium, high and low value?
Bonne journée.
Olivier (other developper
Nice Idea! Let me see what I can do.
