[APP][Pro] Konnected Home Security & Garage
Connect and control your Konnected devices with the Native API.
FEATURES
• 19 Dedicated Drivers for every device type
• Secure Connection with API password and Encryption Key
• Native API for fast and reliable communication
• Multi-Language support (EN, TR, DE, FR, ES, IT, NL, SV, NO, DA, PL, RU, AR, KO)
SUPPORTED DEVICES
• Alarm Panel (with Alarm System Interface support)
• Lights (dimmable, RGB, color temperature)
• Switches & Smart Plugs
• Climate / Thermostats / AC
• Fans (single and dual)
• Covers / Curtains / Blinds
• Locks
• Garage Doors
• Ratgdo Garage Door Opener
• Motion Sensors
• Door/Window Sensors
• Multi Sensors (motion + light + temp + humidity)
• Smoke Sensors
• Gas Sensors
• Water Leak Sensors
• Air Quality Sensors (PM2.5, CO2)
• Energy Meters
• Sirens
• Buttons
SETUP
  1. Enable the Native API in your Konnected configuration
  2. Add the device by selecting the appropriate driver
  3. Enter the device’s IP address, port (default: 6053), and credentials
KONNECTED CONFIGURATION
api:
encryption:
key: “your-encryption-key-here”
password: “your-api-password” # optional
All devices automatically detect and report WiFi signal strength when available.
KONNECTED ALARM PANEL: ENCRYPTION & PIN CODES
The Konnected Alarm Panel driver fully supports Encryption Keys and Alarm PIN Codes natively configured on your Konnected devices!
• Encryption Key: Enter the key in the device’s Advanced Settings to securely authenticate and maintain the connection.
• Alarm PIN Codes: Put your default PIN code in Advanced Settings to Arm or Disarm (Away, Home, Night, etc.). The app will automatically use this.
Note: When you change the Encryption Key or other connection settings, the app will automatically restart the connection in the background to apply the new settings immediately.
  • PayPal Support: If you like my work and want to buy me a coffee: PayPal.Me
I just loaded this app and have both my Alarm Panel Pro 12 Zone board and my 6 Zone Alarm Panel working great, Picked up all the Zones, Sirens and Alarms.
If you are like me, my panels were on the Legacy Konnected firmware. This app requires your Konnected Panels to be on their ESPhome firmware. Konnected switched to ESPhome in early 2023. So if you haven’t updated firmware recently likely you are in the same boat as I was.
Before you start, make sure to write down the IP address of the Panel. You will no longer be using the Konnected app from Konnected.
You can make the switch by using the Konnected install tool - NOT the app, (https://install.konnected.io). Requires the Chrome browser. Plus you need to connect to the micro USB port on the Panel, not over Wifi or ethernet. You need a data cable from your Mac or PC. A power only cable will fail. For the Mac, when you follow the install, you should see a popup showing a serial cable connection. If that doesn’t show try flipping the usb-c cable connected into your Mac upside down, really this can make a differenece depending on the cable you use. Another thing, if you have the power connected to the panel that can also cause an issue, pull it and let the USB power the Panel. After you update the firmware and disconnect the USB, just plug power back in.
You will be asked which ethernet version your panel is. Basically unless it is fairly recent you’ll likely select the second option.
Then let it update. Once done it brings up another dialog box saying done, clicking next brings up another, I ignored it. Firmware was updated. Then pull the usb off the panel and plug the power back in if you had removed it.
Then go to the Homey Pro and add the panels with this app. For me I only needed to enter a name and the IP address. The default port worked fine and I didn’t need any passwords.
The app will find all the zones and sirens and alarms.
And yes, you will need to rename them.
I hope this helps, let me know if you have issues.
v 1.1.21
Redundant items on the main GDO card have been streamlined.
A toggle function has been added to the main GDO card to remove STR Output, Pre-Shutdown, Restart, Play Sound, Resync, Reset Timers, Reset to Factory Settings, and distance values.
These functions have been reorganized so that they remain on separate device cards.
STR Output remains controllable via GDO Flow actions in the background.
New Flow actions have been added: Stop garage door
Run pre-close warning
Restart garage door opener
Turn on STR output
Turn off STR output
The “STR Output On” and “STR Output Off” options have been added to the General Garage Door action card.
A unit conversion for distance measurement has been added: m, mm, and inch values have been normalized to cm.
Distance support has been added to the Sensor Distance card.
History/Statistics has been enabled for distance properties.
button_press_event has been made into a visible event sensor; button history can now be tracked.
In the new GDO mapping, diagnostic/setup entities such as WiFi, Signal, RSSI, Run Time, and Calibration are no longer included in the sub-device list.
Wired, Distance, STR, and Button/Switch/Binary sensor entities remain as sub-devices.
V 1.1.23
Security and stability update.** Pairing pages now securely process the names provided by the device, and passwords/encryption keys are no longer logged in the app logs. Fixed: When switching between alarm modes, the “Alarm Off” message no longer appears briefly, and incorrect schedule notifications are no longer sent; the “Alarm status is changing to” Flow trigger now activates in Alarm System Interface mode as well; the garage light brightness is now displayed correctly; battery and fan speed sensors that report in % are now paired correctly; changing garage door connection settings now allows for reconnection without requiring a app restart. Konnected firmware scope has been improved: The Security+ protocol selector is detected more reliably; the GDO blaQ synchronization status now appears as an “Not Synchronized” alarm; a new “Door Openings” counter has been added via Insights; voltage monitoring sensors can now be added as Energy Meter sub-devices, and technical values (client ID, rolling code) are hidden from the main GDO card. Background logging has been reduced, and various connection reliability issues have been resolved.
What’s New
  • Fixed an app crash caused by closing an already-ended ESPHome connection.
  • Added compatibility for newer ESPHome entity messages, including firmware update entities.
  • Increased the entity discovery timeout for panels with many entities.
  • Improved cleanup after failed connection and authentication attempts.
  • Prevented failed connections from continuing to retry in the background.
  • Added clearer messages for encrypted and unencrypted ESPHome API configurations.
  • Updated the pairing screen to clarify that the encryption key must be left blank for unencrypted Konnected firmware.
  • Improved reliability when pairing Konnected Alarm Panel Pro devices.
V 1.1.24
Version 1.1.25 — mproved connection reliability for Konnected and ESPHome devices. Increased the ESPHome handshake timeout for devices on slow or weak networks. Fixed an app crash when closing an already-ended connection. Added compatibility with newer ESPHome entity messages, including firmware update entities. Increased the entity discovery timeout for panels with many entities. Improved cleanup after failed connection and authentication attempts. Prevented failed connections from continuing to retry in the background. Added clearer guidance for IP address, port, Native API, and encryption configuration errors. Clarified that the encryption key must be left blank for unencrypted Konnected firmware. Improved Alarm Panel Pro pairing reliability.
V.1.1.25
