[APP][Pro] Bosch Indego Lawnmower
:house_with_garden: Bosch Indigo Lawnmower
Control your Bosch Indego smart robotic lawnmower with your Homey.
Pair your device:
Follow the steps during the pairing step in the app. You will end up on a blank page, which is expected behavior. From your developer tools, copy the complete request URL from the ?state call. It’s easy to find if you type in the search field ‘code’
Copy the whole code in the appropriate text field:
And click on ‘Search lawnmowers’.
:warning: The code is only valid for a short period of time, therefore complete the pairing process as quickly as you can.
Important notes:
  • This is not an official app supported by Bosch. Therefore, there is no guarantee that the API will always be available.
  • Login is only possible via SingleKey. Follow all instructions step by step; otherwise, we won’t be able to retrieve the lawnmowers linked to your account.
  • Since your Indego communicates via a mobile connection, there will always be a delay between a Homey command and your mower’s response. This may even result in Homey timeout messages, but this should not affect the functionality of the app.
  • The Bosch API is becoming more stable, but still experiences occasional downtime. When this happens, the Homey app will temporarily not work.
Support:
If you’re unable to pair, feel free to contact me. Always include a screenshot of your developer tools and the code you’re trying to copy.
Supported models:
In principle, all Indego smart models are supported. This app has been tested on the Indego S500+, but should normally work on other models as well.
Contribution:
This app is based on the Home Assistant Bosch Indego implementation: GitHub - sander1988/Indego: Home Assistant Custom Component for Bosch Indego Lawn Mower · GitHub
