[APP][Pro] Creality - Control your Creality 3D printers
Hello everyone,
I have developed an app to add Creality K series printers for Homey Pro and released a test version.
After adding the device, simply enter its IP address in the device settings. Widget support is available.
I hope you like the app, and any feedback is always welcome! I strive to respond to all requests as quickly as possible, but since I have a regular job, I will work to fix any issues as soon as I can.
Work perfect with my K2 Pro :blush:
Helps me turn off my printer after end print
\Søren
Works great! I cannot turn of my Creality Hi with it, but made a flow and placed a switch behind it.
Could it also control XYZ axis to home the unit?
Thanks for your efforts!
Unfortunately, it is not possible to turn off the printer directly. The power button is used to turn off the printer’s light. I will see what I can do for XYZ axis control.
:wrench: Fixes
  • WebSocket connection changed to on-demand (short connections) — Creality Print and phone app can now be used simultaneously
  • Light button state now updates instantly in the widget when changed from the printer’s own app
  • Widget height adjusted, removed extra whitespace at the bottom
  • Increased spacing between temperature cards and control buttons
:sparkles: New Features
  • Home all axes (G28) — device button and Flow action
  • X, Y, Z axis movement Flow actions — configurable distance (mm)
:high_voltage: Improvements
  • Printer state syncs faster after commands
  • Reconnect time reduced from 10s to 3s
  • Fixed infinite retry loop in initCapabilityListeners (max 10 retries)
  • Enlarged print preview area for better visibility
  • Dynamic preview background color derived from image content
  • Improved contrast handling for dark/bright preview images
  • Fixed Android dark/light theme rendering inconsistencies
  • Optimized widget visual balance and control spacing
Hi, I’ve been looking to get into 3d printing (using the Creality 3D SparkX i7 Combo 3D Printer) and came across this homey app. The compatability list says that i can use my homey pro early 2019, but the app description says “requires Homey Pro 2023 or later.”. So im assuming that this app wont work on my specific homey? Would i be able to use the app if I were to upgrade to Homey Self-Hosted Server? As this upgrade is something on my to-do list anyway. Thanks!
Hello, unfortunately, I can’t assist you at this time because the 2019 model of Homey doesn’t support widgets. You’ll need Homey software version 12.3 or higher.
Thanks for the fast reply! When using Homeys dashboard feature the 2019 is able to use widgets (i know as i use them already from some apps ;p). In relation to your unedited message, i will let you know when I receive my printer!
Hoi ugrbnk wat een goed plan, kun je ook eens kijken om de andere printers ook toegang te geven, ik heb namelijk een CR-M4 i.c.m. een SonicPad die ik heel graag met homey wil bedienen.
ik zou het erg fijn vinden om een melding te krijgen wanneer een print klaar is bijvoorbeeld.\
in elk geval bedankt voor jou moeite om een app te maken.
Hi, I’ll send you a test version later today to help you. If you test it and give me feedback, I’ll do my best to support you.
ugrbnk super bedankt ik zal jou ook helpen waar ik kan en wellicht werken we samen om dit te fiksen, dan heeft iedereen er wat aan toch. ik programeer regelmatig alleen wel vooral met behulp van ai dus ik ben geen programeur, ik zie je bericht wel verschijnen
Could you try the test version and let me know?
Hi ik heb het geĂŻnstalleerd echter krijg ik bij allebei de nieuwe printers de onderstaande melding, ik kan de andere printer die je eerder in de normale versie ook had wel installeren, echter accepteert deze mijn ip of poort niet. ik heb geprobeerd om een andere poort toe te passen, ik kwam op reddit een paar poortnummers tegen die bij de sonicpad zouden horen alleen werken ze niet helaas.
Yes het is gelukt maak er maar versie 1.0 alleen het poortnummer was niet goed en ik dacht bij mezelf als ik nu poort pak voor ssh en dat heeft gewerkt. Super bedankt voor je hulp en het maken van de app.
Mocht je nog meer hulp of testen neem alsjeblieft contact op en ik zal je helpen
I’m glad the issue was resolved. Port numbers for Creality devices may vary. I’ve set the standard Klipper port as the default for you. You can change this port to match your specific device. Finally, could you please test the widget and let me know how it goes?
Widget werkt ook top wel moet ik dadelijk even kijken waarom ik geen cam beelden heb denk dat het aan mijn systeem ligt aangezien ik ook in de Creality app en in browser geen beeld heb.
Als ik niet terug kom werkt het top ik ben er in elk geval super blij mee en eerste flow heb ik al gemaakt.
Even een update ik zie net dat de widget op geen apparaat beschikbaar dat duurde een minuut ongeveer en is nu weer terug. Ik kon wel gewoon in het apparaat kijken en daar werkte wel alles.
Okay, I think I’ve solved that problem. There was a bug that caused the widget to disappear for a while when it wasn’t getting a response from the instant printer; I fixed that.
