[APP] Popup
This is the topic for the app Popup.
This is a widget app build to send text messages to your dashboard.
usefull for a log or to-do list.
The app provides a widget with which you can send texts messages to your dashboard with a flow.
on the dashboard the next functionality’s are possible:
:white_check_mark: Check the item
:pushpin: Pin the item
:cross_mark: Delete the checked items
Widgets:
Flow example:
Changelog:
1.2.0 22 jan 2026 test
Autoclean-up setting added. rules can be automatic deleted after x hours / days
1.1.3 22 jan 2026
Pinned rules can’t get delete anymore.
1.1.2 22 jan 2026
check all box added
1.1.1 22 jan 2026
button style changed
1.1.0 21 jan 2026
Made the Checkbox a option in the settings.
1.0.3 19 jan 2026
widget image changed and add text EN language.
1.0.2 16 jan 2026
doneer knop gewijzigd
1.0.1 16 jan 2026
donation button
1.0.0 15 jan 2026
First version!
if you like the app popup.
a small donation is appreciated. even 1 euro or less.
Paypal.me
new update: check your flows on corruption because of adding a key field!!!
With the delete flow card you can delete texts from your dashboard.
As an example:
washing machine is ready.
And you have a button on the washing machine to indicate that it has been emptied.
Then the text can be deleted from the dashboard with the button and a flow.
In the send text to dashboard card you enter the text and a unique key. In the delete flow you also add this unique key to delete it.
