[APP][Pro] ASUSTOR
This app can read data from your ASUSTOR NAS.
  • CPU usage
  • Disk usage
  • RAM usage
It can also check if a LAN port is connected via a condition Flow card. More features will be added soon.
Setup Instructions
To use this app, you need to enable EZConnect services on your NAS. To enable EZConnect, you need to log in to your NAS and open the Settings app. You need to register for an ASUSTOR account. If you haven’t yet registered your NAS with your account, click the “Product Registration” tab first, and complete the account creation.
You can now go to the EZConnect tab. You’ll need to enable EZConnect and set an EZConnect Cloud ID, this ID can be used to access your NAS remotely using [cloudid].ezconnect.to.
Access methods
This app uses the EZConnect service to find the NAS IP, and attempts a local connection first using all LAN IPs. In some cases, this isn’t possible. For example when your NAS is outside of your home. In this case, it will try the WAN IP and MyASUSTOR DDNS service to establish a remote connection. When this method also fails (f.e. when you haven’t forwarded the port), it will use the cloud relay. Note that the cloud relay connection might be slower and less reliable, so it isn’t recommended
reserved
Version 1.0.2
  • Remove update available trigger as it doesn’t work
  • Rename Asustor to ASUSTOR
Version 1.0.3
  • Fixed Flow card name
Nice you developed this. Not yet tested, but that will be in the near future.
Version 1.0.4
  • Added forum topic ID and issues URL to the app manifest
Version 1.0.5
  • Update dependencies
Version 1.0.6
Version 1.0.7
Version 1.0.8
  • Added tags for app store visibility
Version 1.1.0
  • Added Flow cards for enabling and disabling apps
Version 1.1.1
  • Added app enabled condition Flow card
Version 1.1.2
  • Added maintenance actions for reboot and shutdown
Version 1.1.3
  • Added Dutch translations
Version 1.1.4
  • Added Dutch README
Version 1.1.5
Version 1.1.6
Version 1.1.7 [LIVE]
