[APP][Pro] NextDNS
View your NextDNS analytics and use them in your Flows. You can also add and remove domains from the blocklist and the whitelist from Flows.
You can modify from how long ago you want to see DNS requests. By default, it shows DNS requests from the past 24 hours. However, if you go into the device settings, you are able to set the time range
Let me know if there are any other features that you would like to have added
Version 1.0.1
  • Added URLs
  • Fixed a typo in the pairing screen
Version 1.0.2
  • Improved pairing and repairing process
Version 1.0.3
  • Fixed API key check
Version 1.0.4
  • Updated README files
Version 1.0.5
  • Added add/remove from blocklist action cards
Version 1.0.6
  • Added whitelist flow cards
There appears to be an issue with the icon being very small on mobile. I mostly use the web app where it shows up fine, so I didn’t realize it. I’ll try to fix it later today
Version 1.0.7
  • Fix icons on mobile
Version 1.0.8
  • Update dependencies
Version 1.0.9
  • Set service device class instead of sensor for the profile driver
Version 1.0.10
  • Improved handling of the API key input field when no key was entered
Version 1.0.11
  • Fixed pairing views
Version 1.0.12
Version 1.0.13
Version 1.0.14
Version 1.0.15
Version 1.0.16
  • Fix pairing views
Version 1.0.17
  • Fix README
Version 1.0.18
  • Fixed unavailable status
