[APP] iRobot - So you can human
Central topic for questions/discussing the iRobot App. You can use this topic to ask questions and share your experiences with the devices from iRobot.
This thread is not actively monitored by iRobot Corporation or Drenso. For official support use the e-mail link in the AppStore Support Contact ».
My Roomba j7+ was replaced under warranty with a Roomba Max 705. The Max 705 uses a different app
Although I can add it to Homey, control from Homey seems to be limited. In particular, it no longer seems possible to use the Start Favorite flow card.
In other words, I can only initiate a mission to vacuum the whole house, whereas I need to be able to specify which rooms need to be vacuumed.
Any ideas on how I can accomplish this?
Anyone been able to successfully add devices using this app? Not much guidance on setup and when logging in to add device shows no devices found. API issue?
Wonder if could be possible to add to the application event when Roomba is stuck. Strange that even mode change does not have mode for that. Though, IFTTT integratio somehow detects it.
Hi good evening all. Just installed this app to add my Roomba j7. If I try to setup new device im rooted to site to login and than its states I can leave the page but nothing happens. It just go’s back to install a device how many times I try and login on the Roomba site nothing happens.
Hope some can help me
Oh, you should try again using https://my.homey.app on a computer. The Homey mobile app has a known multitasking issue you can work around using the website.
Hi Bert
Thanks in advance I’ll try that when im home and let you know if it works.
Hi Bert thanks I could add him on the web base but something went wrong. Now I can’t add it anymore and it doesn’t show op in the app any suggestions?
Sorry it was a success thanks all the web base did it. I had to uninstall the roomba app and start over again now its running as a charm.
Thanks again for the help Bert
