Meian plug-in Siren SR01 app for testing
I’ve developed a working app for the Meian SR01 plug-in siren.
https://github.com/WJGvdVelden/MeianSiren
It can be controlled for mode (siren-only, sound-only, both), the duration of the alarm, the alarm volume and be used as a kind of doorbell, with flows or via settings.
The light can also be turned on/off, but the colorControl capability is not implemented.
As this is my first attempt to write a full app on a device, I would appreciate more experienced developers to have a look at the code and give feedback or tips or hints how to improve it or make it more according standards.
I have developed based on a lot of remarks by others in the forum, the work of Johan Bendz (it is a Tuya device, but with quite some deviations) and attempts by the community of Home Assistant, although the version with HA does not work reliable apparently. I hope they can benefit as well.
The code can be found https://github.com/WJGvdVelden/MeianSiren.
The id of the device is
“manufacturerName”: “_TZ3000_cipibmnp”, “productId”: “TS0224”,
Thanks for any input
I get a 404 webpage. Page can not be found.
Is that just me.
On Chrome and Firefox.
Same here
Maybe https://github.com/WJGvdVelden/com.tuya.zigbee was ment?
Maybe because the repository is labeled as Private. Have to figure out how to change that if that’s the problem.
Now it should be visible
No, the address is correct. But the visibility was set to private. It is now changed. Thanks
