Heimdall - Let Homey watch over your home
New version published
Version 1.0.22
  • Added Last Door functionality
  • Split Trigger Delay to 2 separate settings, Arming Delay and Alarm Delay
  • Changed Delay range to 0-300 seconds
  • Minor layout changes to settings pages
The Last Door functionality will shorten the arming delay when ‘the last door’ is closed to 10 seconds. You don’t have to do anything special to use it, just make sure the door sensor has Delayed Trigger set to yes in the settings and you would obviously use a delay setting the Surveillance Mode
Make sure the door is closed when you set your desired Surveillance Mode and just leave through the door, opening and closing is will activate the Last Door functionality which lowers the delay to 10 seconds.
Because this functionality was added the Trigger Delay was split into two separate settings: Arming- and Alarm Delay, please set them to your desired value in the range 0-300 seconds.
