Time function in a flow to tile?
I am using the time functions in the flow, but this is not perfect as I have to change this time sometimes.
Is there a way to get these function in a tile where I can set the time from the app without entering the flow?
Let’s say I would like the time to be 6 and 10 instead of 07 and 11.
Kind regards
Yes, use TIMEY
have fun!
You might be able to achieve this by:
  • Creating variables for each timestamp that you want to change;
  • Use the Timey app (as indicated above) for the WHEN cards, as that app allows variable inputs;
  • Put the variables on your Dashboard and change them from there using the Logic widget:
For triggering flows on time best create Alarms if you have a Homey Pro.
Trigger on a specific Alarm or any allarm that contains an fe EventXYZ in the name if you have multiple events.
Fe:
  • EventXYZ workday 6u30
  • EventXYZ weekend 9u00
I didn’t quite get what the difference between Timey and Homey’s own date and time cards were?
I think solution will be the easiest. I created alarms from the app and named them. I am fully able to adjust the time from the phone without entering the flow.
Thnak you!
I felt this was much more work than just implementing the alarm card from the phone app into the flow.
