TelemetryCollector-Api for developers
Minimal lightweight logging for Homey Apps
This module will be used in a Homey app to send logs to the TelemetryCollector App.
This module is implemented as a mixin pattern to simplify the use of the interface.
(For more information about mixins, see: > Useful Links > Mixins)
Setting it up
Install
npm install homey-telemetrycollector-api
Add permission
"permissions": ["homey:app:org.cflat-inc.telemetryCollector"]
Install TelemetryCollector-Api
require('homey-telemetrycollector-api').install;
Use it
this.logDebug('So easy it goes');
API
Error: error conditions
this.logError('logError-Message');
Warning: warning conditions
this.logWarning('logWarning-Message');
Notice: normal but significant condition
this.logNotice('logNotice-Message');
Informational: informational messages
this.logInfo('logInfo-Message');
Debug: debug-level messages
this.logDebug('logDebug-Message');
Code examples
Homey.App
'use strict';
const Homey = require('homey');
// Install the TelemetryCollector Api
// Development
const inspector = require('node:inspector');
if (process.env.DEBUG === '1') {
  try {
    inspector.waitForDebugger();
  } catch (err) {
    inspector.open(9229, '0.0.0.0', true);
module.exports = class MyApp extends Homey.App {
  async onInit() {
    this.logInfo('App has been initialized');
Migrations guide
Preferred
Rename the methods, it’s fast (global search & replace), the code is more readable and the method calls the console message at the end anyway.
  • this.log() > (renameTo) > this.logInfo()
  • this.error() > (renameTo) > this.logError()
  • this.debug() > (renameTo) > this.logDebug()
Useful Links
Logging
Mixins
ToDo
Thanks
Special thanks to all for the help in testing the new version.
Disclaimer
Use at your own risk. I accept no responsibility for any damages caused by using this app.
Copyright
© Chris Gross / cflat-inc.org, 2025
Good to know
Not all console messages are output in debug mode.
During the HP2023 beta phase, I already noticed that no console message is output for classes that inherit directly from the “Homey.SimpleClass”. I reported this to Athom and received the response “It works as designed”.
But the TelemetryCollector-Api sends the message to the agents in any case.
Enhancement of the log message
Each message text is automatically enhanced by the api with the class name and, if available, the name of the device.
this.logInfo('Initialized')
‘[ClassName] > [Message]’ result: ’ MyApp > Initialized’
‘[ClassName] > [DeviceName] > [Message]’ result: ‘MyDevice > Sample Device > Initialized’
Log message and metadata.
Metadata is added to each log message. These can be used by the observability servers as filters (labels).
Example:
  level: "debug",
  message: "PlayerDevice > Büro 31 Audio > setUnavailable()",
  timestamp: "2025-03-01T09:20:28.364Z",
  metadata: {
    app: "WiiM",
    appID: "org.cflat-inc.wiim",
    facility: "17",
    facilityName: "Device",
    class: "PlayerDevice",
    deviceID: "FF98F09C-74E9-46A5-07FF-155EFF98F09C",
    deviceName: "Büro 31 Audio",
  1. For later use
  1. For later use
