SwitchBot keypad
Does anyone have experience from the SwitchBot Keypad?
I read somewhere that it is compatible with Homey, but I can’t find it in the app or anywhere on this forum.
Any insight on this product? Any good? Will it work with Homey?
Many thanks
Here’s all the info, found by a search in the dedicated switchbot topic;
It seems to communicate with Switchbot Lock, not to Homey as standalone unit:
https://community.homey.app/search?context=topic&context_id=42296&q=Keypad&skip_context=false
you can not use the keypad with homey, like peter says, it only comminucates with the lock.
Thank you @Peter_Kawa & @Robin_De_Lange.
Too bad the keypad won’t work alone. Will continue to look for a stand alone keypad that works with Homey.
Thanks again
No problem!
Ring keypads:
Hi @LinaN,
To keep the forum clean as possible please search the forum or better the appropriate topic first in future. If you cannot find an answer, please ask your question in the future in the appropriate topic (if available) as linked in the App store, or use the search to centralize questions about a specific App or device/brand.
[APP][Cloud & Pro] SwitchBot (Release 1.1.51, Test 1.1.56)
This also applies to the Ring Keypad:
Ring Security - Extend Heimdall with Ring Security products
Because you have already marked this topic as solved and you now have information about where you can find out more about the Ring KeyPad, I closed the topic.
If you have any problems with that please feel free to contact me or another moderator.
