I am using the sun events in my flows for lowering my sun blinds. I would like to add a trigger that lowers the blinds on a particular azimuth. I built a flow that works whenever the azimuth changes but it keeps triggering every time. Who has the solution?
Azi what… was my first thought, but google explaned
Wel if you have a trigger like something Aziwhat has changed, then ofcourse it will trigger every time it changes. So try to use a logic card in the AND part (example is exactly … or lower then x Aziwhat)
Hi …
You can add a line that disables the flow as a final line …
“Then” - switch of flow X
Also creat a flow that activates the sunblind flow again at lets say 3.00 in the morning.
That way the flow gets disabled when the minute the azimuth is > and does not re-trigger
Thanks guys, I will give it a try!
