Sonoff NSpanelPro
This looks good! Did you modify the NSPanel Pro for this?
And could you share more details about the custom webapp you made?
Thanks.
possible to share an how to and/or webapp?
I like this, but i have no idea how to do this…
Could you make a (small) howto?
Hi @Kringloper
I just got mine NS Panel pro, was able to do all the setup to get adb running, and it seems to work, however I am not able to install a native homey app via adb (it does not show in the launcher), and installing it via the ā€œaptiodeā€ store, it does install however the latest version (Feb. 4 2025) crashes.
I am also not able to install the Smartdash (can’t find an .apk) only a xapk.
-edit:
I’ve managed to install the xapk, the app starts but then displays a warning on the nspanel pro that Google Plays is not enabled, and therefore does not start…
Any suggestions for me? Thanks!
Maybe you will find the answer to your question here [Pro][Dashboard] SmartDash - a dashboard for Homey
Thanks, bit of digging, but managed.
Same here. Looks simple and clean!
How did you do this?
I tried doing the same, but with the currently latest version of Homey (9.4.2), but it fails to work correctly. I can install the apk, but it simply won’t load. Any other insights on this, as which versions do work, or how to install the latest correctly?
Could you explain what digging and how you resolved it? I’m happy you were able to install and run, but that does not help others.
For those who were struggling like me, here is how:
Make sure you have the adb tool ready to use. You can download the tool from Sideload Apps to Sonoff NSPanel Pro | Blakadder’s Smarthome Shenanigans
Make sure you have the latest version of the NSPanel SW installed through the root panel tools: seaky/nspanel_pro_roottool_apk
Install the root panel tools on the device:
.\adb.exe install nspanel-pro-roottools-1.0-release.apk
Download the latest version of the Sonoff SW OTA versions: https://drive.google.com/drive/folders/1bHLLJy8vYUjkCCnyUmrHgEFWi_2cxywv
Push the downloaded SW to the device:
.\adb.exe push CoolKit_Sonoff_480P_20240306_3.0.0-ota.zip /storage/emulated/0/system_update.zip
The Homey app is in xapk format, you’ll need an installer for that: XAPK Installer 4.6.4.1 (nodpi) APK Download by TarrySoft - APKMirror
.\adb.exe install -r xapkinstaller_4.6.4.1.apk
Download the Homey app and push it to the device: Homey — A better smart home 8.2.2 APK Download by Athom B.V. - APKMirror
.\adb.exe push ā€œHomey — A better smart home_9.4.2_APKPure.xapkā€ /storage/self/primary/Download/Homey.xapk
This will place the xapk in the Download folder.
Start the XAPK installer and install Homey
Homey has launched this app. Anyone tried to control Homey devices from the NSPanel PRO via this app?
