Smalldata Widgets
Small data widgets!
This app is designed to save space on the dashboard.
The Smalldata app ensures that you can store a lot of data in a minimalist way.
Infinite possibilities with the use of data from your devices.
Addition of Snapshots.
All data is flowmap-oriented, so it can be processed in any flow.
Suppose you want to see the temperatures of the entire house during a certain action, this can be arranged.
Only to see other data afterwards.
If you like this app, don’t forget to give it a like!:+1:
If you really love the app, a small contribution would certainly be appreciated! :heart:
Small data widgets!
Deze app is ontwikkeld om ruimte op het dashboard te besparen.
De Smalldata app zorgt dat je minimalistich en toch veel data kwijt kan.
Oneindige mogelijkheden met het gebruik van gegevens uit je apparaten.
Toevoeging van Snapshots.
Alle data is flowcard gestuurd dus in elke flow te verwerken.
Stel je wilt bij een bepaalde actie de temperaturen van heel het huis zien is dit te regelen.
Om vervolgens daar na weer andere data te zien.
Vind je deze app leuk vergeet hem dan niet een like te geven!:+1:
Mocht je de app echt geweldig vinden wordt een kleine donatie zeker gewaardeerd! :heart:
Been playing about with this today and works well.
I wondered on whether its possible to say have a 1 x 2 widget and have a text tag as the second widget?
I have a reolink doorbell and with the Gemini AI app ( [APP][Pro] Gemini AI - Control your Smart Home with Google's Gemini ) It creates a text tag and describes who’s at my front door and sends me a push notification and timeline notification of the answer. Would it be possible to say have the text tag as the second widget?
That would be pretty neat and just what im looking for similar to a HA timeline dashboard widget I was using
Hello
Thank you for the application
Can you make the height dynamic according to the content because if we only have 2 lines the total block is too imposing
Merci
will see what I can make. I just don’t have time in the near future. is on the to do list!
Do you have a picture or screenshot what you want?
Hi there dynamic hight is a problem to install on widgets. I’m still searching to finf a solution for this. At this moment i don’t have much time. But will look at it later.
No problem. The text data field is only one line , Is it possible to have it multiple lines of text.
Have you tried whether this works in the other data tiles? Here you can also place a tag/token in the text. If this works it would be a lot easier to build.
I made this. Saving the individual snapshot for review is very difficult and I also suggest doing that as a push notification with the Telegram app, for example. I tried to make the rules when and by whom the doorbell rang with a loop of text so that you can say more. is this what you are looking for? I use notifications myself for when the doorbell rings on my other developed app where you can also enter this. just search for the Popup app.
dynamic height is only possible in widget, but unfortunately not to adjust the entire widget. so I will have to create a separate widget for each size. Can you provide a screenshot that you would like to see adjusted?
Hi , Yeah that’s what I’m looking for. Rather than one line of text more text to fill the data field.
Ill have a look at the popup widget as well. Thankyou
test version is online now!
New update coming!
New flowcard for colors.
Customizable colors for the value or title or both.
Use hex codes to choose your color.
If the criteria do not match, the color is automatically reset to white.
useful for heating, cooling, alarms and more.
Hi @zuur
Do you have an explanation why the top tile is not working and the lower one is working?
Nothing happens when I test the top tile
Thanks in advance
Great widget
Rogier
hi Rogier, I suspect that your variable value at the top flowcard does not display. I assume you see the title. which widget do you use? what you can do to test create a push notification with alarm input 2 and see what is displayed on your phone. If this is not the case, it will not show anything in the widget either.
Let me know if there is still a bug.
Sorry I bothered you. I just found out that my fibaro smart implant (z-wave) left the Homey after I changed from Homey 2023 to 2026 2 weeks ago
Rogier
Hi @zuur
Non of my contactsensors will show up in the Small Data (Camera-Data) widget
Text, Numeric and all other Booleans are working fine except for all the booleans which are being available in a contactsensor.
A further wish would be that I can change True / False to Open / Close within the widget settings instead of making a convert logic for each variable
Thanks in advance
Great app
Rogier
