It’s actually not that different, although my intention is almost the opposite.
I currently have exactly three reasons for keeping my Homey Pro 2026 — apart from the fact that I genuinely still like Homey:
- as another Thread Border Router; together with Home Assistant and my Apple devices I currently have six active TBRs, with another one available
- to continue supporting the users of my apps and other Homey users where I can help
- as a future backup automation system
For my personal needs, Home Assistant has become the primary system. I find it more powerful, more stable in my setup and, surprisingly, even more readable once automations become very complex. At some point, structured logic with Choose, Scripts and Helpers becomes easier for me to follow than a huge canvas full of crossing connections.
Because I use Matter devices, they can be paired natively with both systems using Matter Multi-Admin. Each controller manages the device directly; Homey does not depend on Home Assistant and Home Assistant does not depend on Homey.
At the moment, my old Homey automations are disabled. But my plan is to create a second, much simpler automation layer on Homey.
For example, my shutter system in HA is far too complex to reproduce sensibly in Homey. But basic opening in the morning and closing at night is easy.
The same applies to heating. In HA I am building logic that decides between TRVs and air conditioning based on temperatures, efficiency and the financial comparison between oil heating and the heat pump. I wouldn’t try to reproduce all of that in Homey.
But something basic such as:
window opens → heating off
window closes → heating on
is very easy to implement there.
Eventually, both systems will have one master switch controlling all their automations.
If HA completely fails, I simply enable the Homey flows.
If HA is still running but has a serious problem, I disable its automations and enable the Homey ones.
The house would then lose some intelligence, but it would continue to function at a perfectly usable basic level.
So for me Homey may actually become something quite valuable: an independent fallback automation system for Home Assistant.
