SDK question regarding setDeviceCapabilities
Apologies for a perhaps dump question (still very limited in knowledge about homey sdk and java scripting), but the here’s something I can’t get to work.
I am using the 433mhz example from the SDK pages, and got it working to receive a signal. However what I would like to do is upon receiving the signal, setting the device capability to on or off,
So in my device.js is the following;
mySignal.on("payload", function (payload, first) {
  console.log("Signal received")
  this.setCapabilityValue('onoff', false).catch(MyDevice.error);
and produces the following error:
Signal received
[HomeyClient] homey:manager:rf.onEvent Listener Error: TypeError: this.setCapabilityValue is not a function
    at Signal433.<anonymous> (/app/drivers/test/device.js:81:16)
    at Signal433.emit (node:events:525:35)
    at ManagerRF._onEvent (/node_modules/@athombv/homey-apps-sdk-v3/manager/rf.js:39:24)
    at /node_modules/@athombv/homey-apps-sdk-v3/lib/HomeyClient.js:111:13
    at Array.forEach (<anonymous>)
    at HomeyClient._onMessage (/node_modules/@athombv/homey-apps-sdk-v3/lib/HomeyClient.js:109:19)
    at EventEmitter.emit (node:events:513:28)
    at /homey-app-runner/lib/App.js:157:26
    at new Promise (<anonymous>)
    at /homey-app-runner/lib/App.js:156:18
How would it be possible to access the setDeviceCapability in that function?
Change function (payload, first) to (payload, first) => your this scope it not bound to the surrounding scope. When using an arrow function the this is bound to scope it was defined in.
Many thanks for this!
To extend the question a bit more; a similar error is given when you try to access the capabilities from the app.js How would you deal with this outside its own device class? i.e if I would like to check a device state in the app.js ?
this.homey.drivers.getDriver('someid').getDevice(deviceData)
or
this.homey.drivers.getDriver('someid').getDevices()
and find the device.
Much appreciated!
