Run a script from another script
I tried several ways to launch a script from another one
I’m note sure that my way is the best one
try {
  const url = \`http://127.0.0.1/api/app/com.athom.homeyscript/script/${encodeURIComponent(SCRIPT_ID)}/run\`;
  const response = await fetch(url, {
    method: 'POST',
    headers: {
      'Authorization': \`Bearer ${API_KEY}\`,
      'Content-Type': 'application/json'
    body: JSON.stringify({ args: \[payload\] })
  if (response.status === 401) {
      console.error("Clé API refusée (401). Vérifier API_KEY .");
      return;
  const data = await response.json();
  console.log(\`Réponse : OK\`);
} catch (e) {
  console.error(\`Erreur : ${e.message}\`);
Just to be sure : do you want feedback on this script to optimize it or is this script not working and you want help to get it working ?
I’m a bit confused about what you want to know :slight_smile:
That API key expires quickly AFAIK. You’d need the full token refresh logic as well if this is a permanent solution.
