Ring Security - Extend Heimdall with Ring Security products
New version published:
Version: 0.2.1 Beta
  • Support for Ring Keypad from the 2nd Generation added
  • Added setting to suppress “Sensor Active at Arming message” on Ring Keypads
  • Reorganised Ring Keypad settings
  • Code cleanup
Thanks to Robbshop I have been able to add support for the 2nd Generation of the Ring Keypad.
In this version the basic functionality is added but some functionality will be added later, most noticeable the option to use the 2nd Generation Ring Keypad as a Sirene. Compared to the 1st Generation Ring Keypad the 2nd Generation Ring Keypad is missing some options so I have to figure out how to enable certain functionality, if possible at all. On the other hand it’s much better looking and more importantly it has proximity detection so it lits up when you get close to it when its dark so I still prefer this new version.
Also added in this version is an option so you can suppress the “Sensor Active at Arming message” as per request by @Rob_Bruining (Github Issues #3)
And lastly, in preparation of a new function for the Ring Keypad (1st Generation) I’ve reorganised the settings page.
