[Requests] Homey Pro Community App Requests
What is the brand:
Warema - Webcontrol Pro
What is/are the device(s)/service for type:
Sunshade
What kind of category/signal(s) would the app use:
IP (Local)
Is there an (public) API / documentation / manual(s) or known (other) implementations (like Blogs/Github etc)?
API-documentation:
warema_2064534_alhb_de_v0.pdf
API-Postmann Collection:
API Postmann Collection
Produkt website:
https://www.warema.com/de-at/smart-home/wms-webcontrol-pro/
Are you willing to loan or donate to a developer?
Yes, donate money €
Extra information:
There is an integration into the HomeAssistant system. However, only an awning and scenes work there:
What is the brand:
Mammotion
Robomower Luba and Yuka series
wifi and cloud
GitHub - mikey0000/Mammotion-HA: Home Assistant integration for Mammotion lawn mowers
Yes, I can let developer log in to my Mammotion account for testing
Extra information:
What is the brand :
  • Ratio
What kind of device would you like to be added :
  • Ratio EV wall charger
What kind of category signal would the app use :
  • IP i guess? / cloud access
Is there a (public) API / documentation or known other implementations (like Blogs/Github etc)
  • not that i’m aware of sadly.
https://www.ratio-electric.com/en/products/ev-chargers/ev-chargers/ev-charger-ratio-solar/groups/g+c+a+view
Are you willing to loan or donate a device to a developer?
  • Sorry not possible since it’s on the wall outside my house, i can provide all needed information and contribute some if needed.
Segway Navimow series, Robot mower
API
Should be availible
Dont have a device to loan out, but willing to donate money for development
What is the brand:
Hoymiles
Examples:
Solarpanel omvormer
  • IP (Local/Cloud/WiFi); Integration with their Cloud portal
Yes, there is already a homeassistant integration so for developers this should give a good headstart I guess:
hoymiles-api/docs/api/readme.md at master · Xinayder/hoymiles-api · GitHub
Extra information:
Hoymiles have plug and play solarpanels so more and more users will have these…
I have the HMS-800W-2T model.
What is the brand:
Universal
Show a tile with a user’s location, maybe a actual map, or just an address. Some sort of find-my-iphone without Apple knowing your location. Homey already knows the location of our devices and adding it as a tile/(favorite device) to the homescreen would be great.
  • Other (Please explain); I guess all the needed code is already in the app, it just needs a new ‘device type’ which would be a map or address
  • Yes, donate money €100
What is the brand:
Dormakaba
Dkey smart lock
  • Bluetooth (BLE)
    • This device also have a IP gateway, but only for remote access via app.
Dormakaba dKey - Home Assistant
Extra information:
What is the brand:
FUJITSU ATLANTIC
  • Airconditioning
  • Zigbee
No Official API
Private cloud API (as used in Node-RED or gduteil integration).
Node-RED users managed to access Cozytouch data using Atlantic’s cloud API, simulating OAuth2 authentication (grant_type=password), and then retrieving a JWT token to query the API. These make it possible to read data (temperature, states, etc.) from connected equipment such as heating or air conditioning.
  • Yes, donate money €, Yes, if the application is maintained in the long term, not if it is an app without any support
**What is the brand:**
Somfy (with Zigbee Motors)
**What is/are the device(s)/service for type:**
  • Roller blinds
**What kind of category/signal(s) would the app use:**
  • Zigbee
**Is there an (public) API / documentation / manual(s) or known (other) implementations (like Blogs/Github etc)?**
**Are you willing to loan or donate to a developer?**
**Extra information:**
Apperently Somfy uses its own Zigbee network but there is a way to let the device pair with other regular Zigbee networks (See Reddit thread above):
“I have been able to pair a Sonesse2 motor with zigbee2mqtt, and the trick was so simple that I can´t even believe it, I just had to hold the button of the blind for 10 seconds (instead of 5 seconds the manual says) and the blind did 2 consecutive jogs and it immediately joined the zigbee network. It seems by default the blind creates its own zigbee network, and by holding the button longer it enters a different pairing mode to join other networks”.
I tried this method using the “Somfy Sonesse2 28 Wirefree Zigbee, 2Nm/20tpm, Li-ion’ device and it connected to my Homey Pro but was recognized as a ‘Unknown’ device’ that only had one operation ( = on/off) that was not supported. So it did not do anything. But it connected! So my guess/hope is that adding some usefull functionality (most usefull is just up and down) should hopelfully not be very difficult.
**Brand name**
Bliq Energy
**Device**
10 kWh SAJ battery with the Bliq Energy management system
**What kind of category/signal(s) would the app use**
The energy management system can be connected to the router, internet
**API / documentation / manual(s) or known (other) implementations (like Blogs/Github etc)?**
Public information: Swagger UI
Information about the EMS: Bliq energie management systeem voor thuisbatterijen
It depends on if it can be successfull made
Why I do want to have the app: In my Homey I have my car integrated and my car charger integrated. The only data I need for now from Bliq is the current battery level of the home battery. When this level reaches for example 80% I want to charge the car to decrease the battery level. So the trigger should execute a Homey flow that starts charging the car.
If we can extract more data from the energy management system, it will be ok ofcourse.
What is the brand:
Big Ass Fans
Examples:
  • Fans
  • WiFi
  • Matter
  • Yes, donate money $
What is the brand:
Bosch HomeCom easy
Internet gsteway K40RF for heatpump’s
  • WiFi
    API
It seems to exist for homeassistent. See link :
Aurora 13a Zigbee Smart Double Socket with Power metering
  • Model Name AU-A1ZBDSS
Zigbee Model - DoubleSocket50AU
Zigbee 3.0
Works with SmartThings and HomeAssistant
I cant sorry but I will provide any info i can. I have full device jason from SmartThings
What is the brand:
Melcloud Home
  • Airconditioning
  • air-air heater
  • water-air heater
  • I will donate some beer money
Extra information:
Would be fun if anyone could have a look at the integration for Home Assistant and create similar for Homey.
What is the brand:
Adeo lexman
LDSENK02F ADEO 16A EU smart plug
switch (state), power_on_behavior, power, voltage, current, energy
zigbee
What is the brand:
Ring (Amazon) without Ring hub
Siren outdoor
  • Z-Wave;
I haven’t found any APIs. The only information I’ve found is in the Z-Wave EU manual.
https://manual.zwave.eu/backend/make.php?lang=en&sku=5AT3T4&cert=ZC12-21030201
  • Yes, donate a device
  • Yes, donate money €/$/£
Extra information:
I am trying to add a simple outdoor siren to my Homey ecosystem so that it can be activated when my outdoor motion sensors detect movement and I am not at home. I tried searching the apps to see if there was anything available, but these products are difficult to find as they are no longer on the market (e.g. Popp). Since the Ring by Amazon siren offers an economic and easily available alternative, it would be great to be able to integrate this device directly into Homey Pro/Mini/Self using Z-wave. I purchased one and managed to connect it to my Homey Self through Homey Bridge, but once connected as a generic Z-wave ON/OFF device, it does not function.
What is the brand:
ELCO (i.e ELCO AEROTOP S.2) from ELCO Heating Solutions
Heat pump / Heating (Air-to-Water) + Domestic Hot Water (DHW)
Local IP (Modbus TCP on LAN)
Not a public “web API”, but Modbus TCP is a standard industrial protocol.
ELCO provides Modbus register documentation for installations using Modbus TCP (typically available via installer documentation / on request from ELCO or heating installer).
Other implementations exist in the home automation world via generic Modbus integrations (e.g. Home Assistant Modbus TCP), but there is no dedicated Homey app for ELCO Aerotop S2.
As it will be difficult to loan a heat pump, I am willing to donate money.
Extra information:
Goal is a Homey Pro community app dedicated to ELCO Aerotop S2 over Modbus TCP (local only).
Minimum viable features: read-only sensors (outdoor temp, flow/return temp, DHW temp, operating mode, compressor status, alarm/fault).
Optional controls (if registers allow): enable/disable heating and DHW, adjust setpoints/curve offset.
What is the brand:
Navimow
Robotic lawnmowers
WiFi, Bluetooth, 4G
