**What kind of category/signal(s) would the app use:**
IP (Local/Cloud/WiFi);
AEG app
Home Assistant Access Steps:
The Home Assistant feature allows the energy storage system to be integrated with a Home Assistant smart home
environment.
Through this integration, system data can be displayed and used for monitoring or automation within Home Assistant.
Preparation Before Access
Before enabling the Home Assistant function, please ensure the following conditions are met:
· A Home Assistant hardware environment is already installed and running
· A computer or device is available and can access the Home Assistant runtime environment
· A valid GitHub account
· A valid Home Assistant account for Sunpura integration
AEG
Compressed Package Directory Contents
After downloading the Home Assistant access package, the directory includes the following files:
· Access Instruction Manual: step-by-step guidance for installation and configuration
· HA-EMS-panel.mjs: EMS display panel for visualizing system data
· HA-EMS-local.zip: local communication plugin for connecting the system within a local network
· HA-EMS.zip: cloud communication plugin for remote data access
Users should select and install the appropriate plugin according to their Home Assistant setup and network
environment.
The Home Assistant access package can be downloaded from the following link:
**What is the brand:** Boneco. **What is/are the device(s)/service for type:** Air Purifier, Humidifier **What kind of category/signal(s) would the app use:** - Wifi **Is there an (public) API / documentation / manual(s) or known (other) implementations (like Blogs/Github etc)?** I don’t know **Are you willing to loan or donate to a developer?** No **Extra information:** No
What is the brand: Zeekr What is/are the device(s)/service for type: Cars What kind of category/signal(s) would the app use: Wifi Is there an (public) API / documentation / manual(s) or known (other) implementations (like Blog s/Github etc)? I don’t know Are you willing to loan or donate to a developer? No Extra information: No
What is the brand: heypolo
What is/are the device(s)/service for type: Presence
What kind of category/signal(s) would the app use: Website
Is there an (public) API / documentation / manual(s) or known (other) implementations (like Blog s/Github etc)? Probably not
Are you willing to loan or donate to a developer? Yes, money
There is also some form of integration directly to the smart meter and/or E.ON databases using a code on the smart display provided by E.ON. USwitch, a UK company that provides comparison data for a number of areas, including energy contracts, uses this to access a customer’s historical energy data
Happy to beta test and provide access to smart display code if this is the chosen development approach.
EV charging station. Specifically the Ratio chargers managed through the official Ratio app (including the Ratio Solar). The app would show charging status and power, and allow starting/stopping a charge.
Via the cloud API behind the official Ratio app (AWS Cognito authentication + REST). Optionally also Bluetooth (BLE) for local control without the cloud (the charger uses the Inspiro IPC protocol over BLE).
Yes. There is an open-source, reverse-engineered Python client and a working Home Assistant integration:
aioratio (async Python client for the Ratio cloud API, including optional BLE): Github
Home Assistant integration by the same author: Github
The API is not officially documented by Ratio itself; the projects above document the endpoints, the Cognito authentication flow and the data models quite thoroughly in their READMEs.
Yes, donate money
Extra information:
There is no Ratio app in the Homey App Store yet. A working prototype build by myself (with Claude and no programming knowledge) already exists, built with the Python Apps SDK + the aioratio library: pairing with a Ratio account, plus capabilities for power, charging state, car connected, charging blocked, grid-operator power reduction (DSO), error/fault alarm, firmware-update available, and (approximated) kWh.
REIRI is a Daikin control system that can manage air conditioning, heat pumps, ventilation and other connected devices. A Homey app could display and control REIRI management points, including:
On/off
Current and target temperatures
Heating, cooling, fan and automatic modes
Fan speed
Ventilation mode and status
Equipment status and faults
Indoor-air-quality measurements, where available
These capabilities could then be used in Homey Flows and Advanced Flows.
Other: REIRI communicates with Daikin equipment and can also integrate selected Modbus and Z-Wave devices.
A local IP integration would be preferred. REIRI controllers connect to the local network, and Daikin’s technical FAQ identifies network ports 80, 52000, 52001, 52010 and 123. The exact local protocol does not appear to be publicly documented.
There does not appear to be a publicly documented third-party API. However, the following official information and applications may help:
Daikin New Zealand – REIRI for Home:
Daikin Australia – System Controllers:
Daikin REIRI product information:
Official REIRI technical FAQ, including network, Modbus, Z-Wave and Google Home information:
REIRI Setup Tool for Android:
REIRI Setup Tool for iOS:
A separate REIRI user application is available for controlling the system.
REIRI already has a Google Home integration. Daikin states that air-conditioning and Z-Wave management points can be transferred to Google Home. Available air-conditioning controls include on/off, target temperature, operating mode and fan speed. This indicates that an existing interface for accessing REIRI management points may be available, although it is not publicly documented.
The controller forms part of a permanently installed system, so it cannot readily be removed. However, I would be willing to assist a developer remotely with testing, diagnostics and non-sensitive technical information from an operational REIRI system.
Extra information:
There is currently no known Homey app supporting Daikin REIRI.
An initial read-only app would still be useful if full control cannot be implemented immediately. Ideally, a completed integration would provide Homey capabilities and Flow cards for:
Reading current temperatures
Reading and changing temperature setpoints
Turning equipment on and off
Reading and changing operating modes
Reading and changing fan speed
Monitoring ventilation operation
Monitoring equipment availability and fault status
Triggering Flows when temperatures, modes or operating states change
Local communication would be strongly preferred for faster responses, operation without an internet connection and avoiding reliance on a cloud service.
