Recently an update was released, and finally we have an option to show some Homey data on my phone through widgets!
A really simple but welcome feature.
Some future request though.
Could it please be possible to scale the widgets?
Now we are stuck to a fixed format, but I use a phone with high resolution and a larger grid then most phones. Where most phones use a wallpaper grid of max 5 slots wide, mine use 10 slot, so the widgets are displayed very small.
And please a function to display a value from any app or logic value.
So just the number, F.E. the current temperature, or current energy price.
Preferably with the ability to choose your own header/title (because some sensors have the same name), and your own format (like “°C” - “Watts” - “€” or whatever you want).
Adding on to this thread as it’s relatively current, and related directly to improvements of the Android Insights widget; the Insights graphs need to be scaled correctly, or have the ability to NOT scale from zero by default.
Reason being, I have temperature insight graphs for indoor temp, so they only vary between a few degrees each day. However, the actual values are flattened out due to the graph showing zero through to 30 degrees C, per attached.
An alternative widget for the Homey dashboard (so no your phone’s homescreen), is to use the line graph widget from DataVista. That widget allows you to change the range of the Y-axis (to some extent):
