Hi, maybe this information is already mentioned somewhere, however I was unable to find it. Hopefully someone could update the already designed widgets.
I’m creating a homey dashboard, especially for a energy overview.
With the widget ‘energy usage’ it’s possible to select a energy meter and you get a nice realtime overview of the energy. Green when my solarpanels produce a lot of energy and blue when it’s cloudy and i use more power then i produce. Unfornately i can’t setup in this widget a day overview or an hour etc.
To fix this, i use the widget ‘insights’. But the problem with this widget is, that this graphic is in the same color. (always green).
Is it possible to get the same colors as in the attachment. With the blue/ purple and green colors? It’s very hard to see on which moment you get a - value or above the 0 .
Also another solution is, to get more settings in the ‘energy usage’ widget, the same as the ‘insights’ widget, with settings like hours or day/ weeks etc, because the usage widget already have to good colors.
