I wish to set Parameter 14 on the Fibaro RGBW controller to 9999 Hex, = 39321 Dec, (14,2,39321) but Homey gives an error saying it must be - 32768 to 32767.
It will not accept 39321 or -26215, which it converts to 3.
Fibaro is using unsigned parameter values, instead of the normal z-wave standard which is using signed values (what the raw parameter input expects), so you’ll need to send the hex value, not the decimal value: 14,2,0x9999
Thanks. I don’t know whether it has accepted the value, as Honey still gave the range warning.
