In the former version of Homey I run various flows to use the Radio app. In version 2 I can not select the radio app in a flow
What do I miss here?
Regards,
Frans
Hi Bas,
Thanks for your swift reply! how can I invoke the lower part of the screen you showed in your reply?
Regards,
Frans
Just pick the tag in the "play a website-card:
Hi Bas,
Thanks again!
I installed chrome cast on my Homey, it is visible in the apps list under the “… More” button in the Homey app. Then when I try to invoke chrome cast it is not visible in the “Select action” list. by the way other apps are not visible as well…
What went wrong?
Regards,
Frans
You have to add a chromecast-device first as you can have multiple chromecast-devices…
Hi Bas,
I do not have any chromecast devices.
While opening the app it responds that I have no flows and no devices, ho can I make the homey a chromecast device?
Regards,
Frans
You can’t… What do you use to play the radio on? If it’s Homey-out, then please file an issue at :
https://support.athom.com/hc/en-us/requests/new
as Athom removed the possibility to use line-out…
Hi Bas,
Thanks,
I do you the line out 3.5 mm jack on the Homey.
I’ll file the issue.
Thanks for your help.
Regards,
Frans
