Problem With Advanced Flow Creation
I’m trying to create an Advanced Flow in Homey. I have Homey Self-Hosted installed on a Mac mini M4, but the options I need to complete the Advanced Flow are not appearing.
This was working correctly yesterday, so it seems to be an issue that started today. I’m not sure what caused it or how to fix it.
Could you please help me troubleshoot this?
I Edit: I thinks is a problem with the web app, in the web app I cannot make any flow (standard or advanced) when in the iOS App I can make standard flows as usual
Does refreshing your browser / clearing its cache work?
No, is not working.
I have the mcp connection with ChatGPT and it has the same problemas… Flows array is empty, are not accessible outside my local network.
I reviewed my router settings and seems to be all ok and no blocking
Enable the browser console to see any errors popping up.
https://www.ecosia.org/search?q=how+to+enable+browser+console
Did you have any luck in finding the issue?
I’m having the same problem im also running HSH on a mac mini m4
