Possible to use JSON respons from a CURL command as a variable?
Hi!
I wonder if it is possible to do the following… I have a CURL command which retrieves some JSON data:
curl -f -k -H 'Accept: application/json' -H 'Authorization: Bearer MyTokenHere -X GET https://envoy.local/api/v1/production
This gets this response (from my solar panels):
  "wattHoursToday": xxx,
  "wattHoursSevenDays": yyy,
  "wattHoursLifetime": zzz,
  "wattsNow": abc
Now I’d like to have the ‘abc’ number as a variable to use in other flows…
I’m a bit lost cause this is all new to me, but maybe someone can point me in the right direction?
Something like this?
Thanks!
Almost works… I get a response "failed, reason: self signed certificate’
With the cURL command, I can use -k to ignore this, no idea if this is possible in Homey?
rejectUnauthorized: false ensures self signed is allowed
You can try it with HomeyScript if you have that installed. There is a Flow card that can run a code snippet and return a text token.
Hard when this is no longer available under Homey Pro 2023
You should tell the developer of the app.
Just use logical en use GET then put in the URL https://envoy.local/api/v1/production header Accept: application/json
Authorization: “Bearer Mytokenhere”
Cache-Control: no-cache
Host: bearer
Accept-Encoding: gzip, deflate, br
Connection: keep-alive
Don’t you need to add a variable in the body ?
A body in a GET request doesn’t make a lot of sense. Also, don’t use that particular Accept-Encoding header since Homey’s Logic card cannot handle compressed responses.
