Hi everyone,
I’m new to Homey app development and trying to set up my environment to create my first app (SDK v3). The goal is a Zigbee app for the ID Lock 202 Multi (using the Datek module, identifies as “ID Lock 150” / “Datek”) for my Homey Pro 2023. Unfortunately, I’m completely stuck due to a persistent error during homey app run and homey app build.
Problem: When running homey app run or homey app build in the project folder, the command fails almost immediately during the “Pre-processing app…” stage with an EPERM: operation not permitted, rmdir error. The specific subdirectory it fails on varies (e.g., ...\.homeybuild\assets, ...\.homeybuild\node_modules\color-space, ...\.homeybuild\node_modules\hsluv).
Example error message:
✓ Pre-processing app... × Error: EPERM: operation not permitted, rmdir 'C:\HomeyDev\com.arnberge.idlockzigbee\.homeybuild\node_modules\color-space'
Note: On a couple of rare occasions earlier in troubleshooting, I got past the EPERM error, but homey app run then immediately crashed with TypeError: Class extends value undefined is not a constructor or null (even with Node LTS and homey-zigbeedriver installed via npm install). This might suggest the underlying environment issue also affected runtime, but the EPERM error is the consistent blocker now.
My Environment:
- OS: Windows 11 Pro 24H2
- Node.js: v20.19.0 (LTS) (Downgraded from v22.x)
- Docker Desktop: v4.40.0 (Engine v28.0.4) using WSL 2 backend (Ubuntu distro confirmed via
wsl -l -v). - homey-cli: Latest version (globally installed via
npm install -g homey). - Project Location:
C:\HomeyDev\com.arnberge.idlockzigbee(Moved from OneDrive to avoid potential conflicts).
Troubleshooting Steps Attempted (without solving the EPERM error): I’ve spent considerable time troubleshooting this with an AI assistant, and we’ve tried the following steps without success in resolving the EPERM issue:
- Switched from Node.js v22 (Current) to v20 (LTS).
- Ran clean installs of dependencies (
npm installafter deletingnode_modulesandpackage-lock.json) multiple times, including after the Node switch and Docker reset.npm installitself completes without errors. - Moved the project folder out of a OneDrive-synced location to
C:\HomeyDev. - Tried running PowerShell as Administrator.
- Added exclusions in Windows Defender (Virus & threat protection → Exclusions) for:
- The entire project folder (
C:\HomeyDev\com.arnberge.idlockzigbee). - The
node.exeprocess. - The
com.docker.backend.exeprocess.
- Temporarily disabled Windows Defender Real-time protection.
- Checked “Controlled folder access” (it was ON). Tried allowing
node.exethrough it (didn’t help). Also tried temporarily disabling the entire Controlled folder access feature (didn’t help either). - Ran
docker system prune -ato clear Docker cache/resources. - Reset Docker Desktop to factory defaults (via Settings → Troubleshoot → Reset factory defaults).
- Tried running
homey app runwith the--cleanflag. - Confirmed WSL 2 is active and used by Docker (
wsl -l -vshows version 2).
None of these steps have resolved the EPERM error during pre-processing. Both run and build consistently fail at this stage.
Has anyone experienced similar persistent EPERM errors on Windows 11 with this combination of tools (Homey CLI, Docker Desktop, WSL2)? Any suggestions for further troubleshooting of the build environment interaction with the filesystem would be greatly appreciated!
Thanks in advance!
Best regards, Arne Berge
