I tried showView() and other methods in onPair().
And they do absolutely nothing, they are just ignored, with or without await. Writing in TypeScript, and adding comments like //@ts-ignore
The only option that worked for me was Homey.emit() from View.html to onPair() to make some checks and Callback result to View.html to make a Homey.showView()
Something like this. Even async/await donât work. Also while making pair.emit(""), it not emit and not send it to View.html. In general, not a single pair command does not work, They only works in View.html
Regardless of whether the other methods are declared or not, they should work. Are you sure your HTML page isnât erroring out on something? If youâre not already doing so, run the pairing process from the developer website and keep your browserâs developer tools/console open.
You canât forward users to websites for authentication like that. As far as I know, you need to either use the OAuth2 or the Credentials Login views (it doesnât look like Yandex is using OAuth2), or provide an alternative that doesnât require directing the user to an external website.
