No problem, welcome back!
Yes, I’m on 1.5.12 ; I have tried the Onkyo 2.0.1 and 2.0.2 via Developer Tools, and 2.0.2 via the regular install method, but all three ‘versions’ have the same problem. Only the on-off function works if I manually select it in the Homey app (although I still need to try it like three times), but none of the cards work in flows.
What do the logs show when it crashes? You should try to run it via the developer tools, then you can read the logs. Send it to me in a private message and I will have a look.
Thanks, I will. Hopefully I wont’t spam your inbox with commands.
After the last update on Homey (4.0), the app is not working anymore for me, tried rebooting homey, reinstall the device. reinstall the app but nothing.
It finds the devices and install it, but no respond when i try to do anything, online timeout…
is’t a known problem? or just me?
A known problem after 2 hours? Guess you better send this to Athom support directly including a diagnostics report…
The problem from @DjTail is solved by firmware update of the onkyo receiver.
