NSPanel Pro & Homey Android app
Hi there,
For pretty much a year I’ve had a dormant NSPanel Pro in my wall and a Homey Pro 2023 that was waiting for the final touches to get setup and used daily. Well that time has come but to my surprise I’m not able to start the Homey app anymore. It crashes straight upon launching.
The weird thing is this happens on several different versions and I know one of the last versions that I had installed was 9.0.0 or 9.0.1 because dashboards were definitely included. That worked when I was testing from time to time. But I just can’t get it to launch.
I’ve reset the NSPanel Pro to factory settings a couple of times(5x power off/power on and it reinstall default firmware) and have tried reinstalling Homey with different versions but to no avail.
If anything this is the terminal logcat command:
01-20 01:39:00.015   474   488 E memtrack: Couldn't load memtrack module
01-20 01:39:00.015   474   488 W android.os.Debug: failed to get memory consumption info: -1
01-20 01:39:02.145   474   490 E tangly  : onPointerEvent == ACTION_DOWN
01-20 01:39:02.150  1379  1379 E StartReceiver: onReceive: StartReceiver : android.system.gestures.touchDown
01-20 01:39:02.276   474   490 E tangly  : onPointerEvent == ACTION_UP
01-20 01:39:02.279   474   485 I ActivityManager: START u0 {flg=0x10000000 cmp=app.homey/.MainActivity} from uid 10052
01-20 01:39:02.279   267   888 D AudioHardwareTiny: start_output_stream
01-20 01:39:02.280  1379  1379 E StartReceiver: onReceive: StartReceiver : android.system.gestures.touchUp
01-20 01:39:02.281   267   888 D alsa_route: route_info->sound_card 0, route_info->devices 0
01-20 01:39:02.281   267   888 D alsa_route: route_set_controls() set route 0
01-20 01:39:02.284   474   485 E ActivityManager: getPackageFerformanceMode--ComponentInfo{app.homey/app.homey.MainActivity}----app.homey
01-20 01:39:02.284   474   538 E ResourceType: Style contains key with bad entry: 0x01010586
01-20 01:39:02.288   474   538 E ResourceType: Style contains key with bad entry: 0x01010586
01-20 01:39:02.293   267   888 W StreamHAL: Error from HAL stream in function get_presentation_position: Operation not permitted
01-20 01:39:02.293   474   485 E ActivityManager: getPackageFerformanceMode--ComponentInfo{app.homey/app.homey.MainActivity}----app.homey
01-20 01:39:02.310   474   485 I ActivityManager: Start proc 1578:app.homey/u0a53 for activity app.homey/.MainActivity
01-20 01:39:02.332   275  1165 I [Gralloc]: Got fd 16 for handle 1
01-20 01:39:02.333   275  1165 I [Gralloc]: leave, w : 480, h : 480, format : 0x1,internal_format : 0x1, usage : 0x933. size=921600,pixel_stride=480,byte_stride=1920
01-20 01:39:02.333   275  1165 I [Gralloc]: leave: prime_fd=16,share_attr_fd=17
01-20 01:39:02.333   283   462 I [Gralloc]: Got handle 10 for fd 90
01-20 01:39:02.333   283   462 I [Gralloc]: leave, w : 480, h : 480, format : 0x1,internal_format : 0x1, usage : 0x933. size=921600,pixel_stride=480,byte_stride=1920
01-20 01:39:02.333   283   462 I [Gralloc]: leave: prime_fd=90,share_attr_fd=114
01-20 01:39:02.334   474   538 I [Gralloc]: Got handle 1 for fd 244
01-20 01:39:02.334   474   538 I [Gralloc]: leave, w : 480, h : 480, format : 0x1,internal_format : 0x1, usage : 0x933. size=921600,pixel_stride=480,byte_stride=1920
01-20 01:39:02.334   474   538 I [Gralloc]: leave: prime_fd=244,share_attr_fd=246
01-20 01:39:02.371   283   319 E BufferQueueProducer: [l.l/l.l#0] disconnect: not connected (req=1)
01-20 01:39:02.372  1116  1156 W libEGL  : EGLNativeWindowType 0x75ab5cd010 disconnect failed
01-20 01:39:02.386  1578  1578 D AndroidRuntime: Shutting down VM
01-20 01:39:02.387  1578  1578 E AndroidRuntime: FATAL EXCEPTION: main
01-20 01:39:02.387  1578  1578 E AndroidRuntime: Process: app.homey, PID: 1578
01-20 01:39:02.387  1578  1578 E AndroidRuntime: java.lang.UnsatisfiedLinkError: dalvik.system.PathClassLoader[DexPathList[[zip file "/data/app/app.homey-n05nc1crQU_GuEU7mVXELg==/base.apk"],nativeLibraryDirectories=[/data/app/app.homey-n05nc1crQU_GuEU7mVXELg==/lib/arm64, /system/lib64, /vendor/lib64]]] couldn't find "libpairipcore.so"
01-20 01:39:02.387  1578  1578 E AndroidRuntime: 	at java.lang.Runtime.loadLibrary0(Runtime.java:1011)
01-20 01:39:02.387  1578  1578 E AndroidRuntime: 	at java.lang.System.loadLibrary(System.java:1657)
01-20 01:39:02.387  1578  1578 E AndroidRuntime: 	at com.pairip.VMRunner.<clinit>(VMRunner.java:30)
01-20 01:39:02.387  1578  1578 E AndroidRuntime: 	at com.pairip.VMRunner.invoke(VMRunner.java:53)
01-20 01:39:02.387  1578  1578 E AndroidRuntime: 	at com.pairip.StartupLauncher.launch(StartupLauncher.java:14)
01-20 01:39:02.387  1578  1578 E AndroidRuntime: 	at app.homey.MainApplication.<clinit>(Unknown Source:0)
01-20 01:39:02.387  1578  1578 E AndroidRuntime: 	at java.lang.Class.newInstance(Native Method)
01-20 01:39:02.387  1578  1578 E AndroidRuntime: 	at android.app.Instrumentation.newApplication(Instrumentation.java:1102)
01-20 01:39:02.387  1578  1578 E AndroidRuntime: 	at android.app.Instrumentation.newApplication(Instrumentation.java:1087)
01-20 01:39:02.387  1578  1578 E AndroidRuntime: 	at android.app.LoadedApk.makeApplication(LoadedApk.java:983)
01-20 01:39:02.387  1578  1578 E AndroidRuntime: 	at android.app.ActivityThread.handleBindApplication(ActivityThread.java:5715)
01-20 01:39:02.387  1578  1578 E AndroidRuntime: 	at android.app.ActivityThread.-wrap1(Unknown Source:0)
01-20 01:39:02.387  1578  1578 E AndroidRuntime: 	at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1656)
01-20 01:39:02.387  1578  1578 E AndroidRuntime: 	at android.os.Handler.dispatchMessage(Handler.java:106)
01-20 01:39:02.387  1578  1578 E AndroidRuntime: 	at android.os.Looper.loop(Looper.java:164)
01-20 01:39:02.387  1578  1578 E AndroidRuntime: 	at android.app.ActivityThread.main(ActivityThread.java:6494)
01-20 01:39:02.387  1578  1578 E AndroidRuntime: 	at java.lang.reflect.Method.invoke(Native Method)
01-20 01:39:02.387  1578  1578 E AndroidRuntime: 	at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:438)
01-20 01:39:02.387  1578  1578 E AndroidRuntime: 	at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:807)
01-20 01:39:02.391   474   657 W ActivityManager:   Force finishing activity app.homey/.MainActivity
01-20 01:39:02.402   474   490 I ActivityManager: Showing crash dialog for package app.homey u0
01-20 01:39:02.440   474  1289 I system_server: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
01-20 01:39:02.441   474  1289 I OpenGLRenderer: Initialized EGL, version 1.4
01-20 01:39:02.441   474  1289 D OpenGLRenderer: Swap behavior 2
01-20 01:39:02.441   275  1165 I [Gralloc]: Got fd 16 for handle 1
01-20 01:39:02.442   275  1165 I [Gralloc]: leave, w : 520, h : 213, format : 0x1,internal_format : 0x1, usage : 0x900. size=449856,pixel_stride=528,byte_stride=2112
01-20 01:39:02.442   275  1165 I [Gralloc]: leave: prime_fd=16,share_attr_fd=17
01-20 01:39:02.442   283   317 I [Gralloc]: Got handle 11 for fd 40
01-20 01:39:02.442   283   317 I [Gralloc]: leave, w : 520, h : 213, format : 0x1,internal_format : 0x1, usage : 0x900. size=449856,pixel_stride=528,byte_stride=2112
01-20 01:39:02.442   283   317 I [Gralloc]: leave: prime_fd=40,share_attr_fd=41
01-20 01:39:02.443   275  1165 I [Gralloc]: Got fd 16 for handle 1
01-20 01:39:02.444   275  1165 I [Gralloc]: leave, w : 520, h : 213, format : 0x1,internal_format : 0x1, usage : 0x900. size=449856,pixel_stride=528,byte_stride=2112
01-20 01:39:02.445   275  1165 I [Gralloc]: leave: prime_fd=16,share_attr_fd=17
01-20 01:39:02.445   283   317 I [Gralloc]: Got handle 19 for fd 68
01-20 01:39:02.445   283   317 I [Gralloc]: leave, w : 520, h : 213, format : 0x1,internal_format : 0x1, usage : 0x900. size=449856,pixel_stride=528,byte_stride=2112
01-20 01:39:02.445   283   317 I [Gralloc]: leave: prime_fd=68,share_attr_fd=70
01-20 01:39:02.446   275  1165 I [Gralloc]: Got fd 16 for handle 1
01-20 01:39:02.446   275  1165 I [Gralloc]: leave, w : 520, h : 213, format : 0x1,internal_format : 0x1, usage : 0x900. size=449856,pixel_stride=528,byte_stride=2112
01-20 01:39:02.447   275  1165 I [Gralloc]: leave: prime_fd=16,share_attr_fd=17
01-20 01:39:02.450   283   317 I [Gralloc]: Got handle 20 for fd 113
01-20 01:39:02.450   283   317 I [Gralloc]: leave, w : 520, h : 213, format : 0x1,internal_format : 0x1, usage : 0x900. size=449856,pixel_stride=528,byte_stride=2112
01-20 01:39:02.450   283   317 I [Gralloc]: leave: prime_fd=113,share_attr_fd=126
01-20 01:39:02.451   275  1165 I [Gralloc]: Got fd 16 for handle 1
01-20 01:39:02.452   275  1165 I [Gralloc]: leave, w : 520, h : 213, format : 0x1,internal_format : 0x1, usage : 0x900. size=449856,pixel_stride=528,byte_stride=2112
01-20 01:39:02.452   275  1165 I [Gralloc]: leave: prime_fd=16,share_attr_fd=17
01-20 01:39:02.452   283   317 I [Gralloc]: Got handle 21 for fd 130
01-20 01:39:02.452   283   317 I [Gralloc]: leave, w : 520, h : 213, format : 0x1,internal_format : 0x1, usage : 0x900. size=449856,pixel_stride=528,byte_stride=2112
01-20 01:39:02.452   283   317 I [Gralloc]: leave: prime_fd=130,share_attr_fd=131
01-20 01:39:02.454   474  1289 D mali_winsys: EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, EGLBoolean) returns 0x3000
01-20 01:39:02.459   275  1165 I [Gralloc]: Got fd 16 for handle 1
01-20 01:39:02.459   275  1165 I [Gralloc]: leave, w : 520, h : 213, format : 0x1,internal_format : 0x1, usage : 0xb00. size=449856,pixel_stride=528,byte_stride=2112
01-20 01:39:02.459   275  1165 I [Gralloc]: leave: prime_fd=16,share_attr_fd=17
01-20 01:39:02.460   283   319 I [Gralloc]: Got handle 21 for fd 130
01-20 01:39:02.460   283   319 I [Gralloc]: leave, w : 520, h : 213, format : 0x1,internal_format : 0x1, usage : 0xb00. size=449856,pixel_stride=528,byte_stride=2112
01-20 01:39:02.460   283   319 I [Gralloc]: leave: prime_fd=130,share_attr_fd=131
01-20 01:39:02.460   474  1289 I [Gralloc]: Got handle 2 for fd 253
01-20 01:39:02.460   474  1289 I [Gralloc]: leave, w : 520, h : 213, format : 0x1,internal_format : 0x1, usage : 0xb00. size=449856,pixel_stride=528,byte_stride=2112
01-20 01:39:02.460   474  1289 I [Gralloc]: leave: prime_fd=253,share_attr_fd=254
01-20 01:39:02.477   275  1165 I [Gralloc]: Got fd 16 for handle 1
01-20 01:39:02.478   275  1165 I [Gralloc]: leave, w : 520, h : 213, format : 0x1,internal_format : 0x1, usage : 0xb00. size=449856,pixel_stride=528,byte_stride=2112
01-20 01:39:02.478   275  1165 I [Gralloc]: leave: prime_fd=16,share_attr_fd=17
01-20 01:39:02.478   283   319 I [Gralloc]: Got handle 20 for fd 120
01-20 01:39:02.480   283   319 I [Gralloc]: leave, w : 520, h : 213, format : 0x1,internal_format : 0x1, usage : 0xb00. size=449856,pixel_stride=528,byte_stride=2112
01-20 01:39:02.480   283   319 I [Gralloc]: leave: prime_fd=120,share_attr_fd=126
01-20 01:39:02.482   474  1289 I [Gralloc]: Got handle 3 for fd 256
01-20 01:39:02.482   474  1289 I [Gralloc]: leave, w : 520, h : 213, format : 0x1,internal_format : 0x1, usage : 0xb00. size=449856,pixel_stride=528,byte_stride=2112
01-20 01:39:02.482   474  1289 I [Gralloc]: leave: prime_fd=256,share_attr_fd=257
01-20 01:39:02.514   276   350 I [Gralloc]: Got handle 13 for fd 77
01-20 01:39:02.514   276   350 I [Gralloc]: leave, w : 520, h : 213, format : 0x1,internal_format : 0x1, usage : 0xb00. size=449856,pixel_stride=528,byte_stride=2112
01-20 01:39:02.514   276   350 I [Gralloc]: leave: prime_fd=77,share_attr_fd=78
01-20 01:39:02.680   276   350 I [Gralloc]: Got handle 14 for fd 32
01-20 01:39:02.680   276   350 I [Gralloc]: leave, w : 480, h : 480, format : 0x1,internal_format : 0x1, usage : 0x933. size=921600,pixel_stride=480,byte_stride=1920
01-20 01:39:02.680   276   350 I [Gralloc]: leave: prime_fd=32,share_attr_fd=58
01-20 01:39:02.896   474   489 W ActivityManager: Activity pause timeout for ActivityRecord{393ba2a u0 app.homey/.MainActivity t12 f}
01-20 01:39:02.898   474   489 E ActivityManager: getPackageFerformanceMode--ComponentInfo{l.l/l.l}----l.l
01-20 01:39:02.952   275  1165 I [Gralloc]: Got fd 16 for handle 1
01-20 01:39:02.953   275  1165 I [Gralloc]: leave, w : 480, h : 480, format : 0x1,internal_format : 0x1, usage : 0x900. size=921600,pixel_stride=480,byte_stride=1920
01-20 01:39:02.953   275  1165 I [Gralloc]: leave: prime_fd=16,share_attr_fd=17
01-20 01:39:02.954   283   817 I [Gralloc]: Got handle 3 for fd 115
01-20 01:39:02.954   283   817 I [Gralloc]: leave, w : 480, h : 480, format : 0x1,internal_format : 0x1, usage : 0x900. size=921600,pixel_stride=480,byte_stride=1920
01-20 01:39:02.954   283   817 I [Gralloc]: leave: prime_fd=115,share_attr_fd=116
01-20 01:39:02.960   275   464 I [Gralloc]: Got fd 16 for handle 1
01-20 01:39:02.961   275   464 I [Gralloc]: leave, w : 480, h : 480, format : 0x1,internal_format : 0x1, usage : 0x900. size=921600,pixel_stride=480,byte_stride=1920
01-20 01:39:02.961   275   464 I [Gralloc]: leave: prime_fd=16,share_attr_fd=17
01-20 01:39:02.961   283   817 I [Gralloc]: Got handle 7 for fd 112
01-20 01:39:02.962   283   817 I [Gralloc]: leave, w : 480, h : 480, format : 0x1,internal_format : 0x1, usage : 0x900. size=921600,pixel_stride=480,byte_stride=1920
01-20 01:39:02.962   283   817 I [Gralloc]: leave: prime_fd=112,share_attr_fd=113
01-20 01:39:02.963   275  1165 I [Gralloc]: Got fd 16 for handle 1
01-20 01:39:02.964   275  1165 I [Gralloc]: leave, w : 480, h : 480, format : 0x1,internal_format : 0x1, usage : 0x900. size=921600,pixel_stride=480,byte_stride=1920
01-20 01:39:02.964   275  1165 I [Gralloc]: leave: prime_fd=16,share_attr_fd=17
01-20 01:39:02.965   283   817 I [Gralloc]: Got handle 9 for fd 27
01-20 01:39:02.965   283   817 I [Gralloc]: leave, w : 480, h : 480, format : 0x1,internal_format : 0x1, usage : 0x900. size=921600,pixel_stride=480,byte_stride=1920
01-20 01:39:02.965   283   817 I [Gralloc]: leave: prime_fd=27,share_attr_fd=31
01-20 01:39:02.967   275  1165 I [Gralloc]: Got fd 16 for handle 1
01-20 01:39:02.968   275  1165 I [Gralloc]: leave, w : 480, h : 480, format : 0x1,internal_format : 0x1, usage : 0x900. size=921600,pixel_stride=480,byte_stride=1920
01-20 01:39:02.968   275  1165 I [Gralloc]: leave: prime_fd=16,share_attr_fd=17
01-20 01:39:02.968   283   817 I [Gralloc]: Got handle 10 for fd 90
01-20 01:39:02.968   283   817 I [Gralloc]: leave, w : 480, h : 480, format : 0x1,internal_format : 0x1, usage : 0x900. size=921600,pixel_stride=480,byte_stride=1920
01-20 01:39:02.970   283   817 I [Gralloc]: leave: prime_fd=90,share_attr_fd=118
01-20 01:39:02.972  1116  1156 D mali_winsys: EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, EGLBoolean) returns 0x3000
01-20 01:39:02.997   276   350 I [Gralloc]: Got handle 1 for fd 64
01-20 01:39:02.997   276   350 I [Gralloc]: leave, w : 480, h : 480, format : 0x1,internal_format : 0x1, usage : 0xb00. size=921600,pixel_stride=480,byte_stride=1920
01-20 01:39:02.997   276   350 I [Gralloc]: leave: prime_fd=64,share_attr_fd=71
01-20 01:39:03.027   275  1165 I [Gralloc]: Got fd 16 for handle 1
01-20 01:39:03.027   275  1165 I [Gralloc]: leave, w : 480, h : 480, format : 0x1,internal_format : 0x1, usage : 0xb00. size=921600,pixel_stride=480,byte_stride=1920
01-20 01:39:03.027   275  1165 I [Gralloc]: leave: prime_fd=16,share_attr_fd=17
01-20 01:39:03.028   283   462 I [Gralloc]: Got handle 10 for fd 90
01-20 01:39:03.028   283   462 I [Gralloc]: leave, w : 480, h : 480, format : 0x1,internal_format : 0x1, usage : 0xb00. size=921600,pixel_stride=480,byte_stride=1920
01-20 01:39:03.028   283   462 I [Gralloc]: leave: prime_fd=90,share_attr_fd=96
01-20 01:39:03.028  1116  1156 I [Gralloc]: Got handle 1 for fd 69
01-20 01:39:03.028  1116  1156 I [Gralloc]: leave, w : 480, h : 480, format : 0x1,internal_format : 0x1, usage : 0xb00. size=921600,pixel_stride=480,byte_stride=1920
01-20 01:39:03.029  1116  1156 I [Gralloc]: leave: prime_fd=69,share_attr_fd=71
01-20 01:39:03.049   276   350 I [Gralloc]: Got handle 9 for fd 84
01-20 01:39:03.049   276   350 I [Gralloc]: leave, w : 480, h : 480, format : 0x1,internal_format : 0x1, usage : 0xb00. size=921600,pixel_stride=480,byte_stride=1920
01-20 01:39:03.049   276   350 I [Gralloc]: leave: prime_fd=84,share_attr_fd=85
01-20 01:39:04.136   275  1165 I [Gralloc]: Got fd 16 for handle 1
01-20 01:39:04.137   275  1165 I [Gralloc]: leave, w : 480, h : 480, format : 0x1,internal_format : 0x1, usage : 0xb00. size=921600,pixel_stride=480,byte_stride=1920
01-20 01:39:04.137   275  1165 I [Gralloc]: leave: prime_fd=16,share_attr_fd=17
01-20 01:39:04.138   283   317 I [Gralloc]: Got handle 9 for fd 54
01-20 01:39:04.138   283   317 I [Gralloc]: leave, w : 480, h : 480, format : 0x1,internal_format : 0x1, usage : 0xb00. size=921600,pixel_stride=480,byte_stride=1920
01-20 01:39:04.138   283   317 I [Gralloc]: leave: prime_fd=54,share_attr_fd=69
01-20 01:39:04.140  1116  1156 I [Gralloc]: Got handle 2 for fd 73
01-20 01:39:04.140  1116  1156 I [Gralloc]: leave, w : 480, h : 480, format : 0x1,internal_format : 0x1, usage : 0xb00. size=921600,pixel_stride=480,byte_stride=1920
01-20 01:39:04.140  1116  1156 I [Gralloc]: leave: prime_fd=73,share_attr_fd=74
01-20 01:39:04.166   276   350 I [Gralloc]: Got handle 11 for fd 48
01-20 01:39:04.166   276   350 I [Gralloc]: leave, w : 480, h : 480, format : 0x1,internal_format : 0x1, usage : 0xb00. size=921600,pixel_stride=480,byte_stride=1920
01-20 01:39:04.166   276   350 I [Gralloc]: leave: prime_fd=48,share_attr_fd=52
01-20 01:39:04.167   275  1165 I [Gralloc]: Got fd 16 for handle 1
01-20 01:39:04.168   275  1165 I [Gralloc]: leave, w : 480, h : 480, format : 0x1,internal_format : 0x1, usage : 0xb00. size=921600,pixel_stride=480,byte_stride=1920
01-20 01:39:04.168   275  1165 I [Gralloc]: leave: prime_fd=16,share_attr_fd=17
01-20 01:39:04.169   283   317 I [Gralloc]: Got handle 7 for fd 123
01-20 01:39:04.169   283   317 I [Gralloc]: leave, w : 480, h : 480, format : 0x1,internal_format : 0x1, usage : 0xb00. size=921600,pixel_stride=480,byte_stride=1920
01-20 01:39:04.169   283   317 I [Gralloc]: leave: prime_fd=123,share_attr_fd=124
01-20 01:39:04.171  1116  1156 I [Gralloc]: Got handle 3 for fd 76
01-20 01:39:04.171  1116  1156 I [Gralloc]: leave, w : 480, h : 480, format : 0x1,internal_format : 0x1, usage : 0xb00. size=921600,pixel_stride=480,byte_stride=1920
01-20 01:39:04.171  1116  1156 I [Gralloc]: leave: prime_fd=76,share_attr_fd=77
01-20 01:39:04.200   276   350 I [Gralloc]: Got handle 12 for fd 59
01-20 01:39:04.201   276   350 I [Gralloc]: leave, w : 480, h : 480, format : 0x1,internal_format : 0x1, usage : 0xb00. size=921600,pixel_stride=480,byte_stride=1920
01-20 01:39:04.201   276   350 I [Gralloc]: leave: prime_fd=59,share_attr_fd=60
01-20 01:39:04.201   275  1165 I [Gralloc]: Got fd 16 for handle 1
01-20 01:39:04.202   275  1165 I [Gralloc]: leave, w : 480, h : 480, format : 0x1,internal_format : 0x1, usage : 0xb00. size=921600,pixel_stride=480,byte_stride=1920
01-20 01:39:04.202   275  1165 I [Gralloc]: leave: prime_fd=16,share_attr_fd=17
01-20 01:39:04.203   283   317 I [Gralloc]: Got handle 3 for fd 116
01-20 01:39:04.203   283   317 I [Gralloc]: leave, w : 480, h : 480, format : 0x1,internal_format : 0x1, usage : 0xb00. size=921600,pixel_stride=480,byte_stride=1920
01-20 01:39:04.203   283   317 I [Gralloc]: leave: prime_fd=116,share_attr_fd=117
01-20 01:39:04.205  1116  1156 I [Gralloc]: Got handle 4 for fd 79
01-20 01:39:04.205  1116  1156 I [Gralloc]: leave, w : 480, h : 480, format : 0x1,internal_format : 0x1, usage : 0xb00. size=921600,pixel_stride=480,byte_stride=1920
01-20 01:39:04.205  1116  1156 I [Gralloc]: leave: prime_fd=79,share_attr_fd=80
01-20 01:39:04.230   276   350 I [Gralloc]: Got handle 14 for fd 87
01-20 01:39:04.231   276   350 I [Gralloc]: leave, w : 480, h : 480, format : 0x1,internal_format : 0x1, usage : 0xb00. size=921600,pixel_stride=480,byte_stride=1920
01-20 01:39:04.231   276   350 I [Gralloc]: leave: prime_fd=87,share_attr_fd=90
01-20 01:39:05.410   267   389 D alsa_route: route_set_controls() set route 24
01-20 01:39:05.414   267   389 D AudioHardwareTiny: close device```
Any ideas? thanks in advance
Turns out there was something wrong when getting the apk from aptoide or other places. Installed f-droid, installed aurora and it works.
Tried the same but Homey app crashes. Is it possible to find older versions through the Aurora App Store??
As far as I can see only the most recent one. Have you tried fully restoring the unit to factory settings? 5-6x physical on-off?
Why should I do that? Everything else works except the Homey app? Seems a bit drastic?
I installed f-droid and aurora locally though as ADB could not connect. I do not know if that matters…? ADB connects now though (using a Mac).
