Is there any chance we’ll see device information on Apple Watch, ideally so that it can be added to watch faces for easy access? I know it’s been brought up before but doesn’t seem to have gained a lot of traction - so here’s another attempt.
Can you elaborate? Which Homey info, or device info you mean?
Thanks, the best example is temperature from thermometer sensor read by the Wireless Weather Sensors app, which then can be added to a clock face complication, just as it’s now possible to add Homey to a complication - which basically adds a shortcut to open the Homey app for easy access to the flows configured for the watch.
Tbh, after switching from Telldus to Homey, this is one of the very few features I miss, and ideally all insight values for any device would be made available - but then again, I’m a non-coder so I don’t quite realise the complexity of this request..
I see.
It isn’t even possible (yet) to have, say, a temperature sensor on a smartphone as widget, the only available widgets are for startable flows.
With Home Assistant f.e. it is possible for smartphones:
Smartwatches are supported (just as comparison).
That’s OK, and I guess it’s up to the app devs to decide if and when to put that into the app. I did fiddle around a little with HomeKitty but it wasn’t working out but it’s no issue, I’ll use one of the forecast apps and wait for Homey to hopefully add support for it it in the phone/watch apps.
Cheers // Mike
