Luxtronik Heat Pump Manager — looking for testers
Hi everyone,
I’ve built a new Homey app for Luxtronik-based heat pumps and I’m looking for a few testers to help me stabilise it.
The app communicates locally over TCP (port 8889) directly with the Luxtronik 2.0/2.1 controller — no cloud, no external services required.
Compatible manufacturers
Alpha Innotec/Siemens Novelan/Roth/Elco/Buderus/Nibe/Wolf Heiztechnik/CTA
All sensors
temperatures, state, errors, energy (kWh), …
Control functions
Heating & hot water operation mode, target temperatures
Hot water boost
Force immediate hot water heating with configurable auto-reset timer
Flow integration
Triggers, conditions and actions for all sensor values and control functions
The app is stable enough for daily use, but I’d like to test it across different system configurations — especially with manufacturers and firmware versions I don’t have myself.
Requirement: Luxtronik 2.0 or 2.1 controller reachable over LAN (static IP recommended).
App Store (TEST!!!)
Luxtronik Wärmepumpe | Homey
GitHub repository
github.com/andiwirz/com.luxtronik.heatpump
Install via homey app install in the cloned directory
Feedback, bug reports and pull requests are all very welcome — either here in the thread or directly via GitHub Issues.
Thanks in advance!
Andi
A heartfelt thank‑you to Robin Flikkema for the original foundation of his app.
Novelan WSV 6.2K3M user here. Will test your app on my Homey Pro 2019. Thanks for you efforts.
I have been testing the app for a few days now. I added my heat pump without any problems. Controlling the temperatures and reading all values works perfectly. Thank you!
Thank you as well for your feedback — it’s truly appreciated.
Is there anything you feel is missing or would like to see improved in future updates.
Everything’s fine. The only thing that’s not great is the slider for adjusting the temperature. You can’t see at a glance what temperature is currently set.
Version 2.0.13 — New: Heating Status and Hot Water Status sensors. New: In-app help page. Improved: Thermostat widget for hot water temperature. Improved: Thermal Disinfection target temperature now configurable in device settings (default 65 °C). Changed: Device class set to heater, minimum compatibility raised to >=11.0.0. Fixed: Capability order and labels.
App released - please post questions here: [APP][Pro] Luxtronik Heat Pump Manager – Control and monitor your Luxtronik heat pump - Apps - Homey Community Forum
:point_right: Install from the Homey App Store
