Loss of Zigbee connectivity after some time, reboot of SHS restores connectivity
It is best to keep Zigbee devices that act as Zigbee routers powered on.
If you switch them off, then other devices - that expect those router devices to be available (like devices routed through that device and the coordinator/Homey) - might run into issues. Causing constant Zigbee network reroutes/rebuilds, communication retries and unreliable communication.
Some devices do not search for an alternative Zigbee route automatically, rendering them inaccessible until manually repaired or re-paired.
Thanks for the response!
As of now i have only devices acting as routers. My former issues is that the backend (SHS / Bridge) seems to have forced the whole zigbee mesh net into hung mode through escalating hourly discovery storms followed by ZMemError.
This has happened both with the current single Ikea lamp both on and off. I therefore consider it more likely there are issues in Bridge/SHS and how they handle the mesh. Possibly also due to the older Zigbee controller CC2530 that earlier in this thread (and elsewhere on Internet) is identified as a potential weakness.
I think my fix of increasing times for the more extensive data collection (voltage, power, energy) from the plugs is what has made the system more stable. Still seems to be a minute wise ping to them, but some 75%-ish decrease of calls.
I also think that any zigbee net provocation could been part of what triggered the discovery storms and zmemerrors. Now see that routes do shift somewhat over time - as it should. So will let the net go for a few more days and then try provoke it to see if it finds new routes or end up in discovery storms.
Hopefully last update on this topic from me:
Run SHS on Pi4 + Bridge. 8 cheap TZ3000 plugs plus an ikea lamp in my ZigBee setup using nous plugin/app.
Was stable with Ikea lamp as first ZigBee node for a couple of days (single TX errors) - Then decided to test and power it off. Some more TX errors but low single digit percentages for all devices. And no freeze nor ZMemErrors.
Turned Ikea lamp back on and now only single TX errors over last 4-5 days and no other issues.
So to sum up; Prolonging poll times (prime numbers around 10x original 60 sec) for the additional parameters read (current, voltage, power) did bring a stable SHS-Bridge ZigBee NW.
Thesis: The somewhat outdated Zigbee controller CC2530 in Bridge have performance/data limitations that make i vulnerable and a weak link under some circumstances. Limiting traffic could stabilize it.
