Log all flows
Does anyone have tip when it comes to logging all flows that are active? had been nice to have a log where you could see when they are active. json script? I’m not into scripting. I use power of the hour and would like to see when estimation notice reset e.g.
Not a solution to all flows, unfortunately, but you could add a action to write to the Timeline in the flow, then you would get the timestamp when it’s excuting.
You could use the app Papertrails. You will have add card to all the flows, but for me it works great.
With the push of one button!
Wich card do you use in the flows? You put it in the “Then”?
I am using
DB14973C-B071-4E8B-A9F0-B62F3965E88D_4_5005_c
Which means “Send syslog text”. I am using it to send any line of text to my NAS. In this way I can always do some troubleshooting if something doesn’t work as expected.
What Roco probably meant by “with the push of one button”:
Nice thank you very much​:pray::relaxed:
Exactly!
