Has anyone been able to get the Motion Aware devices to work consistently in Homey? I am running a Homey Self-Hosted Server. When I add a motion-aware device, it works for about 15 minutes, then it stops. I have attempted to repair it, but this does not help. I am also running Home Assistant (trying to migrate from it), and the motion-aware zones work perfectly.
Does anyone have a suggestion on what is causing this problem and/or how to correct it?
I’m not sure if this is still up to date, but here is an easy workaround for this issue:
Create the MotionAware area in the Hue App and temporarily select at least one light (otherwise, the app won’t let you complete the setup).
Once created, open the MotionAware area settings, remove/deselect the light you just added, but make sure to leave the “Turn lights on” option toggled ON.
This keeps the MotionAware zone fully functional and firing events to Homey via the Hue API, without actually controlling or toggling any specific Hue lights directly in the Hue app.
