How to set device value on script
I would need to create function allowing me to change values on devices. Continued trials on on below topic
[Setting Logic Variable by HomeyScript - #53 by Eko_taas]
Example of myDevice (only part of actual AVD)
“_HiidenSite”: {
“devicecapabilities_text-custom_12.text6”: {
“title”: “currentOutTemp”,
“value”: -17.1
as wanted to use more title instead of cabability, made this code for testing reading by title (and working fine):
>   const devices = await Homey.devices.getDevices();
> const sensorName = "_HiidenSite";
> const capabilityTitle = "currentOutTemp";
>   for (const device of Object.values(devices)) {
>     if (device.name === sensorName) {
>       for (const capability of Object.values(device.capabilitiesObj)) {
>         if (capability.title === capabilityTitle) {
>           return capability.value; // Return the capability value (even if it's null)
>       return -1000; // Indicate capability title not found for the sensor
>   return -2000; // Indicate sensor not found
Now wanted to create code to update device value by title… but could only get working within script
//async function setSensorValueByTitle(sensorName, capabilityTitle, newValue) {
  // Get all devices
const newValue = -18.1;
          capability.value = newValue; // Update the capability value with the new value
          device.capabilitiesObj.value = newValue
          return  newValue;
Was not able to figure out how to modify this to get it to Homey-level (and not only till this script)
On earlier mentioned topic can see how to do that for variable, but what to do with when device?
Thanks in advance for any help…
You need to create a capability instance.
Thanks for good advice and direction to go… needed some help with AI to create code but helped a lot how to push it to correct direction :+1:
For records if someone else finds idea useful:
newValue = "-18.2";
          try {
            await device.setCapabilityValue(capability.id, newValue);
            console.log(`Changed '${capabilityTitle}' value to ${newValue} for ${sensorName}`);
            return newValue; // Indicate the value has been updated
          } catch (error) {
            console.error("Failed to update value:", error);
            return -999; // Indicate update failure
      return -1999; // Indicate capability title not found for the sensor
  return -2999; // Indicate sensor not found
Changed ‘currentOutTemp’ value to -18.2 for _HiidenSite
:white_check_mark: Script Success
:leftwards_arrow_with_hook: Returned: “-18.2”
and
