I work on the APIGOTO team. APIGOTO is an independent OpenAI-compatible gateway, not affiliated with OpenAI, Anthropic or Google. This builds on the “[HOW TO] use a local LLM to generate unique notifications” tutorial. The same script works against a local server or any hosted OpenAI-compatible endpoint, because only the base URL and model ID change.
What you need
- Homey Pro (HomeyScript runs locally only).
- The HomeyScript app, scripts at My Homey
- An API key, and a model ID taken from
GET <base URL>/models
1. Test the endpoint outside Homey
curl https://api.china-aiapi.com/v1/chat/completions \
-H "Authorization: Bearer $API_KEY" -H "Content-Type: application/json" \
-d '{"model":"MODEL_ID","messages":[{"role":"user","content":"Say hi"}]}'
2. Store the key once
Create a script called set-llm-key, run it once, then delete the key from the code:
global.set('llm_api_key', 'PASTE_KEY_HERE');
log('saved');
3. The script that calls the model
Create a script called llm-notify:
const BASE_URL = 'https://api.china-aiapi.com/v1'; // or http://<lan-ip>:<port>/v1 for a local server
const MODEL = 'MODEL_ID';
const key = global.get('llm_api_key');
const facts = args[0] || 'The front door was opened.';
const res = await fetch(`${BASE_URL}/chat/completions`, {
method: 'POST',
headers: { 'Content-Type': 'application/json', Authorization: `Bearer ${key}` },
body: JSON.stringify({
model: MODEL,
max_tokens: 80,
messages: [
{ role: 'system', content: 'Write one short, friendly smart-home notification. No emojis, max 20 words.' },
{ role: 'user', content: facts },
timeout: 20000, // node-fetch v2 option, in ms
if (!res.ok) {
log('HTTP', res.status, (await res.text()).slice(0, 300));
return facts; // fall back to the plain text so the Flow still notifies
const data = await res.json();
return (data.choices?.[0]?.message?.content || facts).trim();
4. The Flow
- When: whatever event you want (door opened, washer finished…).
- Then: HomeyScript → Run [code] with [argument] and return Text-tag. Pick
llm-notify. As the argument, write the facts with tags, for exampleWasher finished. Outside temperature: [tag] °C. - Then: Send a push notification (or a speaker “say” card) with the Result tag from the card above.
The script returns the original facts on any error, so a dead endpoint never means a missing notification.
Troubleshooting
- Nothing in the Result tag: open the script editor and run it with a test argument.
log()output shows the HTTP status. - HTTP 401: the key wasn’t saved (run
set-llm-keyagain) or has a trailing space. - HTTP 404:
/v1missing or doubled inBASE_URL. - “model not found”:
MODELdoesn’t match/modelsexactly. - The script stops early: HomeyScript has a run timeout, so keep
timeoutshort andmax_tokenslow. Notifications don’t need long answers. - Privacy: whatever you put in the argument (names, presence, temperatures) goes to the endpoint. A local server keeps it on your LAN.
On the gateway side: one base URL for several model families, automatic failover on upstream errors (at most 3 retries per request on another route), a per-request log, pay-as-you-go, BYOK: www.china-aiapi.com
Which events do you actually want “unique” wording for, and which do you keep fixed?
