Just install it and check it out ![]()
I only missed the cam view!
You got it to work? What do you know - somebody said something incorrect on the internet. I’ll be…
Does the xiaomi app support the scripted functions, like vacuum first, then mop?
I don’t use scripted functions🫣
Ok. With two shedding dogs, that’s actually one of the things I’m most looking forward to. Two runs with the vacuum before mopping to avoid hair being blown into the mopping zone and getting stuck ![]()
Just installed my first Homey ever and decided to start with Roborock S7 cleaner first. After 3 hours of pain - can confirm it was a bad decision =).
But I have way better token extractor for this group of people. Different from method suggested above - it works from the first attempt and extract token momentarily from MiHome account.
Roborock token extractor (tested on Roborock S7)
Hejsan!
So, I have done this SO many times now. But even though I have double checked that I use the same login as I do on my mobile roborock-app (for my Roborock S8) - in the get.token.exe and also tried the token_extractor.exe - but both claim it is an invalid login.
How come the login that I use in the app and Swedish Roborock site (link) works - but not in any of the token extractors?
Would really love to get this to work within home, if only to get the extra WAF-points at home for home-automation. ![]()
Thank you in advance!
Again, please direkt any questions not related to this specific instruction to the app thread ![]()
That Said, you could try this extractor as well: GitHub - PiotrMachowski/Xiaomi-cloud-tokens-extractor: This tool/script retrieves tokens for all devices connected to Xiaomi cloud and encryption keys for BLE devices.
Try changing your password on https://account.xiaomi.com/. Then try the login again on the extractor with the new password.
For those, who are not aware, there is a new Homey app: [APP][Pro] Roborock, without the Xiaomi token - Intelligent robot vacuum cleaners - Apps - Homey Community Forum
app geïnstalleerd en de mi token app op zowel windows en Mac.
Bij starten token app, keurig ip adres en token op scherm van beide stofzuigers.
Alleen bij invoeren van het token in de app van Roborock bij de homey gaat het fout bij het verbinden
Tokens van Mac en windows zijn hetzelfde wat uit de app komt, zowel met versie 1.02 en 1.06 geprobeerd.
Waar gaat het fout? lees meer mensen met dit probleem, alleen een echte oplossing lees ik niet
De roborock app. Die vraagt om een token
De cloud vraagt alleen om email
Wil juist via token, kan dan in honey en ha gebruikt worden
In other words, post your questions into the Roborock app topic. It’s mentioned at the homey.app store app page.
But, while we’re here, this is what worked for me
You’ll need to use this smartphone app, NOT the Roborock smartphone app:
I dont see any mop function on my S8. Is there one? Or is thr ‘clean’ function the same as mopping?
login step 2 failed ![]()
I get this error when trying to clean several rooms. Is it a maximum of rooms allowed to be cleaned?
I tried removing one of the rooms, making the total number of 6 rooms. This worked, but then it started to clean the first 5 rooms in the flowcard. So the last room didnt get cleaned.
Any suggestions to make this work with the number of rooms I want?
Add another card with the remaining rooms?
Probably the room limit is dictated by Roborock.
I tried but then it just selected one of the cards and started cleaning just those rooms.
There is no problem selecting that many rooms in the Xiami/Roborock app so there is possible to select so many rooms for one cleaning.
It fails for me as well - with a known good Xiaomi Home account. I have two S6 and one S7.
