Create a numeric variable
Use the Logics THEN “calculate a value” card
Pick your numeric variable and the textvariable as seen in my example flow below.
→ you should pick the local variable from your webhook.
Keep in mind to delay the card that is used to use the converted text to num variable, while the action flowcards are fired at once (asynchronious).
