I originally installed Home Assistant for a very simple reason.
I was having recurring problems with Homey and Thread/Matter, and I wanted a second system running in parallel mainly to get access to better diagnostic tools.
I quickly realised, however, that HA’s diagnostics are so extensive that finding one specific problem can still take a lot of time. You may need to cross-check logs, traces, entity states and several automations.
So I installed MCP and gave Claude read access to my Home Assistant system. That changed everything. After that, I started migrating my automations from Homey to HA with Claude’s help. During that process, I realised how easy it was to take automations that already felt complex in Homey and push them much further in HA. Claude was also very useful in finding long-standing edge-case problems and checking interactions between automations that I would probably have missed myself.
My five Homey shutter automations eventually turned into 11 HA automations plus several Helpers. But they now cover much more:
That last point made a huge difference for my wife.
If she moves a shutter manually using the physical switch, that shutter is automatically excluded from normal automation for the rest of the day (aside security movements, like opening it in case of a fire).
No mode has to be selected first. Her manual decision simply has priority. For the first time, Smart Home and Happy Wife actually go hand in hand.
The same happened with the dashboard. This is the first dashboard I built that my wife actually likes. It is fully dynamic and allows her to control probably 90% of the house without ever opening a separate room dashboard.
For years, the typical reaction was:
“I hate your Smart Home.”
Now I actually heard:
“I like the dashboard.”
That is progress.
And this is where my view changed completely. Home Assistant itself is certainly more complex to configure than Homey. But once the system is designed around the people living in the house, it can become simpler to use.
My wife moves a shutter manually? Fine. The automation respects that. She presses the hallway button once? The light stays on for 15 minutes and motion automation leaves it alone. She long-presses it? It stays on for 60 minutes. She presses again? The light goes off.
The smart home adapts to her behaviour instead of forcing her to adapt to the smart home. I am not saying that most of this would be impossible with Homey. But there are some things where I honestly don’t know how I would implement the same behaviour cleanly.
For example:
How would Homey reliably detect that a shutter was moved using the physical wall switch rather than by an automation?
How would I build more complex calculations without needing a dedicated app, while HA can often do it with Helpers and templates?
And this leads to a conclusion I honestly didn’t expect. I originally believed that Homey would be the better system for my family because it is simpler and more approachable for non-technical users. In practice, I now think I was partly wrong.
Home Assistant is more complex to build, but if you build it well, it can become easier for the people who actually live with it.
With AI helping with the technical complexity, that setup becomes much more manageable. The result is a system that stays in the background, respects manual interaction and provides an interface dynamic enough that even people who normally dislike technology can enjoy using it.
Subjectively, this is the first smart home I have built that my wife does not complain about. Sometimes she even finds things cool.
My daughter, who mostly ignored the smart home before, now occasionally says:
“That’s so cool.”
To be fair, Homey is still a very nice system.
But at the level of automation I have reached now, Home Assistant is the first platform that gives me the flexibility I want while at the same time keeping my family happy.
I wouldn’t give a point to Homey or Home Assistant for this. That would be a little like comparing a Ferrari with a Maybach. Both are expensive, exclusive cars, but they are designed for very different kinds of drivers. And I think the same is increasingly true for Homey and Home Assistant.
