Touch E3 helps to reduce heating costs by simply controlling the heat in the home. This means that you can keep a lower indoor temperature when you are away but at the same time have perfect heating comfort when you return home. Another feature is that you can now see your energy consumption for each room / zone via Touch E3 heating software.
What kind of category/signal(s) would the app use:
868 Mhz; connection to heating elements from the clever touch e3 panel
IP (Local/Cloud/WiFi); accessing the control panel.
Aqua Temp is widely used for controlling heat pumps for pools. It would be great to be able to do this via Homey. For my part, the only thing i actually need is to be able to read the current temperature. Then I would be able to turn the heating on/off based on current temp and electricity prices.
What kind of device would you like to be added :
Aqua Temp app
What kind of category signal would the app use :
Wifi
Is there a (public) API / documentation or known other implementations (like Blogs/Github etc)
It is an electric fireplace with realistic flames created by evaporating water
Bluetooth (BLE)
Is there an (public) API / documentation / manual(s) or known (other) implementations (like Blogs/Github etc)?
No, but there is an app for android and iphone.
Name of the app. Faber itc v2
Link(s) to where can this be found, the more information, the better.
Are you willing to loan or donate to a developer?
Yes, donate money €100,-
Extra information:
It would be beautiful to add a fireplace to my Flows
With the app on the phone you have a lot of functions
Function control buttons
1 = OFF
2 = ON
3 = flame effect lower
4 = flame effect higher
5 = Heating on/off
6 = Mood setting on/off
7 = volume crackling sound higher
8 = volume crackling sound lower
Water temperature
Air temprature
Redox
PH
Waterlevel
System Alarms
Aseko pool live is used for monitoring water values and automatic dosing system of pools. . If i have the watertemp then I would be able to control the heating based on current temp and electricity prices.
Wifi and access Online or via android or iphone app
YES
