What is the brand:
TFA Dostmann weather hub.
What is/are the device(s)/service for type:
Temperature, rain gauge, wind gauge
What kind of category/signal(s) would the app use:
Is there an (public) API / documentation / manual(s) or known (other) implementations (like Blogs/Github etc)?
A working implementation on GitHub that works with Homebridge
Are you willing to loan or donate to a developer?
Unable to sending a device, as it requires a local gateway, but granting access to my gateway is possible
When a working app is developed I would support the developer financially with a small contribution.
Extra information:
Uses this mobile app:
What is the brand:
APEX
Examples:
Airconditioning (fan coil thermostat)
Light switch.
Yes, donate a device
Yes, donate money 500$
Any additional information needed i will be willing to provide them, thanks.
What is the brand:
Princess
Kitchen appliances, like coffeemaker, water kettle and toaster
WiFi
Unknown
Yes, I’d be happy to contribute to a developer!
Link to manufacturer
https://www.princesshome.eu/en-gb/search?q=Moments
perhaps something for you @Jeroen_Tebbens ?
They seem to be linked to the HomeWizard platform, as they have a dedicated support page for them:
Same a with Link/Climate and Cleaning products of Princess
What is the brand:
Arylic
Arylic provides the best multiroom wireless audio products based on WiFi and Bluetooth technology. Our systems support Spotify, Qobuz, Tidal, Internet Radio, Airplay, DLNA, UPnP. We ship free worldwide, with local warehouses in many markets. 30 days...
Multiroom music players
-IP - Local, LAN or WiFi
https://developer.arylic.com/
https://developer.arylic.com/httpapi/#http-api
What is the brand:
Palazzetti
Palazzetti is positioned as the leader in terms of volume of pellet stove on French soil. The brand offers the largest range of pellet stoves on the market.
They have a connection box called CBOX ( Palazzetti Connection Box ) accessible using local API
Jeedom class : GitHub - DomotechDiscord/Jeedom_Palazzetti
Extra information:
kinou74/Domoticz-Palazzetti: Domoticz Python Plugin for Palazzetti Connection Box (github.com)
_Jo
March 21, 2022, 11:39am
597
What is the brand:
NRGKick Select Bluetooth (not wlan or connect!)
Examples:
Normally you connect to the NRGKick via Bluetooth (Smartphone-App): login with username / passwort and than set Power to charge, Time to start etc.
The OpenSource EVCC.io has a communication on board to work with the NRGKick via Bluetooth
GitHub - evcc-io/config: Configuration templates for EVCC
Extra information:
Important: there exists a “Connect” Version – which uses a cloud-service from NRGkick – this is NOT the preffered way.
The Workflow i have in mind is:
Homey connects to Inverter of PV
Homey can connect to wallbox via bluetooth (like the app)
Homey controlls power and charging trotugh bluettoth based on flows / inverter-data
pv-guided charging
What is the brand:
Balboa Spa bath
Spa bath control
It has a cloud based app:
Set the mood of your spa by ensuring your have the right lighting, water temperature, and your massage pumps running just like you like, all from the convenience of your iPhone® or iPad®. Remotely control the operations of your portable hot tub via...
Link(s) to where can this be found, the more information, the better.
maybe, donate money
No loan possible.
Extra information:
There is an app with intergration on homey called ControlMySpa but this uses a different intergration module than my spa uses.
What kind of device would you like to be added :
What kind of category signal would the app use :
Is there a (public) API / documentation or known other implementations (like Blogs/Github etc)
Did not find it, there is a app in the google play store
Are you willing to loan or donate a device to a developer?
That is not possible, I’m willing to help developing and testing the app.
What is the brand:
CLIMAX
https://www.climax.com.tw/index.php
Alarm System
Detects smashed windows and broken glass door
Wireless for flexible installation
Mounted on wall or ceiling within a 8m range from protected glass
Four selectable sensitivity settings (Max, Medium, Low and Lowest)
Red & Green LEDs indicate test mode, alarms, and tamper conditions.
Tamper protection prevents unauthorized removal
Low battery indicator
Regular supervision signals to check system integrity
Suitable for residental and commercial security applications
Compatible with other manufacturer’s Z-Wave systems
Communication Protocol: Z-Wave Plus 500 series module
Power Source: 3V, CR123 Lithium battery x1
Operating Temperature: -10°C to 45°C (14°F to 113°F)
Dimensions: 75mm x 75mm x 23.8mm
Frequency 868.40 MHz (EU) / 908.40 MHz (US)
Battery Life 1.8 years*
Operating Humidity Up to 85% non-condensing
https://www.climax.com.tw/new/acgs-23zw.php
https://www.climax.com.tw/new/downloads/ACGS-23ZW_Product_News_2021-0524.pdf
https://www.climax.com.tw/new/downloads/Declaration%20of%20Conformity-ACGS-23ZW-OTA.pdf
Yes, loan a device
Yes, donate money €
Extra information:
romiwi
May 2, 2022, 2:27pm
601
What is the brand:
Emotiva (registered trademark)
Examples:
Yes, please refer to Dropbox - XMC-1_remote_codes_and_net_API - Simplify your life
Yes, donate money (paypal in $)
What is the brand:
VITRUM
The Vitrum Wall Switch APP seems to be Abandoned no response from developer. I’m looking to have the APP Upgraded to SDK v.3 and have the Shutter Models added:
https://products.z-wavealliance.org/Search/DoAdvancedSearch?regionId=1&category=-1&brand=156
Extra information:
Example:
Abandoned app, hasn’t been updated in over 3 Years
Laro
May 30, 2022, 7:40pm
608
lvi clevertouch e3 (purmo heating)
Controlling heating elements that is controlled by a lvi clever touch e3 wifi control panel and an app for iPhone, iPad, or web interface.
With Touch E3 heating software you can easily control the electronic oil-filled Yali radiators Digital, Parada, Ramo as well as Purmo underfloor heating and Ulow E2 devices .
Touch E3 helps to reduce heating costs by simply controlling the heat in the home. This means that you can keep a lower indoor temperature when you are away but at the same time have perfect heating comfort when you return home. Another feature is that you can now see your energy consumption for each room / zone via Touch E3 heating software.
868 Mhz; connection to heating elements from the clever touch e3 panel
IP (Local/Cloud/WiFi); accessing the control panel.
Other log-in to account. ( Clever Touch Gen2 )
Only thing I can find is this : LVI clever heating · fredrike/home-config Wiki · GitHub
GitHub - hemphen/hass-clevertouch: CleverTouch - Home Assistant integration…
CleverTouch - Home Assistant integration for Touch E3 radiators - GitHub - hemphen/hass-clevertouch: CleverTouch - Home Assistant integration for Touch E3 radiators
The API used to communicate with the CleverTouch account is located in a stand-alone repository GitHub - hemphen/clevertouch: API for controlling Touch E3-connected radiators via CleverTouch cloud accounts and is also available on PyPi.
Link to English manual for the clever touch e3: https://www.electrorad.co.uk/wp-content/uploads/2015/03/29807-ElectroRad-Touch3-Manual-P2.pdf
Yes, donate money. Loan account
-Harman Kardon
-audio video receiver
-IP/wifi
-There is an excisting app in the (ios)app store called: “HK Remote”
(the pre programmed IR signals for Harman Kardon in homey dont work)
-I will consider a donate…
What is the brand:**
Faber (Also Glen Dimplex and Euro Flame)
It is an electric fireplace with realistic flames created by evaporating water
No, but there is an app for android and iphone.
Name of the app. Faber itc v2
Extra information:
It would be beautiful to add a fireplace to my Flows
With the app on the phone you have a lot of functions
Function control buttons
1 = OFF
2 = ON
3 = flame effect lower
4 = flame effect higher
5 = Heating on/off
6 = Mood setting on/off
7 = volume crackling sound higher
8 = volume crackling sound lower
What is the brand:
Micromatic / Microtemp
Termostat Microtemp WiFi MWD5
Wifi
Not sure
Not for me (just helping), so not sure. Probably.
Extra information:
These thermostats are quite common in Norway
OH2TH
August 12, 2022, 5:07am
635
What is the brand:
Sofabaton X1 - Sofabaton X1 remote is universally compatible with virtually all brands of audio and video equipment. Sofabaton X1
This might be the one to replace eventually Harmony remotes.
Universal remote control with a hub and doesnät rely on cloud to work.
API on local network - However API is still pending
The device can then control:
Infrared (IR);
IP (Local/WiFi);
RF / Bluetooth
API still pending vendor based on their community article Local API - Sofabaton
Does X1 support local API to integrate the remote control into a home automation system without going through the cloud?
Yes, we will open the local API of X1 by providing an API file, but X1 cannot directly add APIs of other products or smart platforms. If you have a deep custom requirement, you can contact our customer services for an API file after receiving the product.
Extra information:
Discussion open in SofaBaton community also Request: An App for Athom Homey Pro - home automation - Sofabaton
Lallu
August 18, 2022, 12:38pm
636
What is the brand:
Pindora
Smart Lock
Yes
Extra Information:
Supports SmartThings. Would be nice if could connect to third party keypad.
What is the brand:
Rhasspy
Voice control
MQTT, HTTP, and Websockets
JSON
https://rhasspy.readthedocs.io/en/latest/usage/#http-api
https://rhasspy.readthedocs.io/en/latest/usage/#mqtt-and-snips
It runs on a Pi
A developer might have one
Extra information:
It would enable Homey to use a non cloud voice recognition.
What is the brand:
Varta
HTTP, Websocket, JSON, XML
Extra information:
Standard inverter communication via TCP Port 502 or TCRIP4 possible
What is the brand:
I think there is multiple brands that work with the AC Freedom app but the one I have is:
AUX split unit airco 2.5 kW incl WiFi
Model number ERP Inverter 9000BTU
IP (WiFi, 2.4GHz (only));
I can control the AC with APP and with Google nest hub. Hub only supports ON/OFF, App has all supported functions.
Github Home Assistant link:
This is the official android APP
No, willing to try things out to see if they work though.
Extra information:
[/quote]
