✨ Homey MCP Server | Megathread
MCP von Athom ( h t t p s mcp athom com)
It again looks like a discovery/session/runtime bridge issue, with the following pattern:
  • Resources are briefly discovered correctly.
  • A first call succeeds.
  • After that, other paths that were previously visible and registered fail with Resource not found.
  • Then discovery disappears completely again.
For a permissions issue, I would expect something more like an auth/OAuth/access-denied error.
For a schema issue, I would expect argument validation errors.
Neither of those happened here.
Having a couple of odd issues using the Homey MCP server with opencode …
The mcp server is defined in ~/.config/opencode/opencode.jsonc
“mcp”: {
// Main Athom-built mcp server - has some limitations
“homeypro”: {
“type”: “remote”,
“url”: “https://mcp.athom.com”,
“enabled”: true
I auth with opencode mcp auth homeypro which opens a browser to select the Homey Pro and allow access. It create a ~/.local/opencode/mcp-auth.json with
“homeypro”: {
“clientInfo”: {
“clientId”: “68ff6xxxxxxxxxxx”,
“clientSecret”: “91116xxxxxxxxxxxxxxx”
“serverUrl”: “https://mcp.athom.com”,
“tokens”: {
“accessToken”: “a62c2e0xxxxxxxxxxxxx”,
“refreshToken”: “9b34e4dxxxxxxxxxxxxx”,
“expiresAt”: 1776975933.498
Agents in opencode are able to access it with no problem. Except the token expires quickly, seems like less than an hour. Doing auth with opencode mcp auth homeypro again says it’s expired, it re-auths, but doesn’t actually re-auth. I have to delete the mcp-auth.json first.
The other major problem is rate-limiting. I have a script that pulls the json for each flow, and it can only grab about 12 before it gets hobbled with "Too many requests …
[MCP] Listing available tools …
[INFO] get_advanced_flow not on local MCP — trying homeypro MCP at https://mcp.athom.com …
[MCP] Step 1/3 — Sending initialize …
[MCP] Connected to ‘homey’ v1.0.0 (protocol 2024-11-05)
[MCP] Step 2/3 — Sending notifications/initialized …
[MCP] Handshake complete — session ready.
[INFO] HomeyPro MCP session established.
→ Fetching rich data for ‘4-button control of front door sockets’ (a318c2e5…)
✓ 4-button-control-of-front-door-sockets-a318c2e5-rich.json
→ Fetching rich data for ‘Back counter light’ (1bc5331f…)
✓ back-counter-light-1bc5331f-rich.json
→ Fetching rich data for ‘Door Window color status’ (b5434476…)
✗ [ERROR] Skipping ‘Door Window color status’ — Too many requests…
→ Fetching rich data for ‘Door/Window reminder when leaving’ (7675c8dd…)
✗ [ERROR] Skipping ‘Door/Window reminder when leaving’ — Too many requests…
Any ideas ?
Great start! It’d be awesome if one could also access homeyscripts using that. There’s no list_scripts, get_script, run_script, or update_script endpoint
Posted in Tutorials but I thought also relevant here: How I built a self-maintaining Homey documentation system with Claude
That script for pulling the flow json files ? It kind of … grew
The ChatGPT app is now live!
https://chatgpt.com/apps/homey/asdk_app_6946bbc90ca4819188f817f992348b98
I got a 404 error when I clicked on the links - it is working now. I see a Homey logo in my chatgpt chat how do I remove or re-add it
Works great this end so far
Let’s see what it can do
Been testing Advanced Flows through the Homey MCP with Claude and hit two related walls.
Reading variables: Creating condition cards that read a Logic variable (equal_boolean) fails every time because the MCP schema doesn’t include droptoken or ownerUri — they get stripped before reaching Homey:
Invalid type for arg ‘droptoken’ expected ‘string’ but received ‘undefined’
Writing variables: variable_set_boolean only works if you already know the variable’s internal ID. There’s no list_variables or equivalent in the MCP, so there’s no way to look them up programmatically. You have to find IDs through other means and hardcode them.
The only workaround for reading state is inline HomeyScript via Homey.logic.getVariables(), but that’s a poor substitute — and global.set/global.get doesn’t survive a reboot, so it’s not a viable alternative for persistent state.
The MCP can technically write Logic variables if you already know their IDs, but can’t discover them and can’t build conditions that read them. Both issues need fixing for Logic variables to be usable through the MCP at all.
I’ve been using ChatGPT with the homey App and it’s been extremely useful. I created a project called “Homey” in ChatGPT, added custom instructions, and now I can generate detailed daily reports covering temperature, humidity, energy consumption, network health, and device status. It has become a simple but powerful way to monitor my smart home and spot issues before they become problems.
My only wish is that ChatGPT App could access Homey’s historical sensor data. Being able to automatically compare current readings with data from previous days or weeks would make the analysis and trend reporting even more valuable.
Interested to know what prompts you gave it for the initial project setup
ChatGPT wrote the prompt. My initial request was simply to create a detailed daily Homey report, and from there ChatGPT did the heavy lifting. I merely served as the copy-paste department. :rofl:
When I ask to build a Advanced flow, GPT reports a problem with list_flow_action_cards:
De Homey-API waarmee ik hier werk geeft op dit moment een fout bij het opvragen van de actiekaarten (list_flow_action_cards), terwijl triggerkaarten wel terugkomen. Daardoor kan ik de flow niet veilig genereren zonder te gokken welke kaart-ID’s jouw apps gebruiken.
I experience this too. But not only with variables.
It is asking a lot for ID’s and names of app functions or states.
Offcourse the names are named different in the API.
To build a fancy flow I often need to set cards in a flow so Claude can read the card and options.
For now it seems like it is much more work to build it with AI then doing it yourself. Beside that your tokens are burned really fast because of the constant rework.
Do Homey devs need to make their app ready for working with AI / MCP-server? It often looks like it has no idea how to use the app’s cards.
Often I see a flow created with cards that are displayed in gray with a ? and something like unavailable or do not exist.
Has anyone else experienced issues with Advanced Flows created by ChatGPT or Claude?
The flow itself works correctly and runs without any problems. However, when I try to edit it through the Homey web UI, for example by clicking “Replace card”, I get the following error:
TypeError: undefined is not an object (evaluating ‘e?.ownerUri.startsWith’)
The flow was generated through the Homey API and appears to be valid (broken: false), but the editor crashes when interacting with certain cards.
Has anyone found the cause or a workaround for this?
Hi all,
Just wanted to share how I leverage ChatGPT with Homey. Instead of using it to build flows, I use it to manage and monitor my two homes under one account and it has been a game changer.
Every day, when asked, it generates a highly detailed, comprehensive report for both properties covering:
1- Climate: Temperature and humidity levels.
2- UniFi Network Status: Device health, latency, and the number of connected clients.
3- Plant Care: Individual plant status and soil moisture levels.
4- Energy: Overall power consumption.
5- Security: Check the status of all doors locks and doors and windows sensors.
On top of the data, it gives me smart recommendations based on the sensor readings like suggesting when to turn on the AC, run the dehumidifier, or close the curtains to save energy. When needed, I can also ask it to generate a direct comparison report between the two houses.
The tag for Homey Pro 2016-2019 is missing in the KB article
It is supported, I use a Homey Pro 2019 and the ChatGPT integration works.
Anyone try the homey mcp server with Hermes agent?
I tried to just add it as an mcp server with https://mcp.athom.com as the server address, but that does not seem to work
Update: I got it to work, in the dashboard I could not so I just had Hermes figure it out.
ChatGPT has helped me enormously with a similar situation. I was impressed with it’s knowledge not only with Homey but vthe Tesla Gateway and my inverters etc.
I have been using ChatGPT with homey through my Chrome Browser. Through using a link prtovided by Athom I get a Chat window which has a Homey symbol in it. I’m afraid to close the tab in case I can’t get it back.
Does anyone know how to access this link? It’s great to just use ChatGPT without having to use any Apps.
