Homey.ink on a tablet/desktop
Me too.
Daneedekruyff and Rocodamelshe got some beers.
Awsome work. Love it <3
Replaced the old one for this one, there may be some caching involved so changes may take some time to be seen.
Thanks for the donation! Much appreciated!
Thanks for clarifying. Totally understand! Again, awesome work!
/jokke
Happy with the results now. Also added actual power value for the plugs.
:thinking:
hd
Is it possible to get a Swedish translation of the dashboard?
Yes, use &lang=sv in the url
Thanks! I’ve tried both sw and se :grin:
IMAG0012
Is it possible to get a dashboard that fits better on a screen like this. It’s a computer screen powered by a raspberry pi.
50155593_1796251527151271_1376188821074345984_n
Mooi dashboard! Je hebt temperatuursensoren in je vriezer en koelkast? Welke zijn dat? En liggen die dan echt in je laden oid?
theme=ipad maybe?
Thanks. It took some effort, but with the code and help from @Ruud, @Rocodamelshekima en @DaneedeKruyff i finally managed it.
And yep, in both freezers and fridges i have the round (non aqara) Xiaomi temperature/humidity sensors (WSDCGQ01LM). Even from the shed (over 10 meters with HR glass and walls in between) they work excellent.
It took a bit of puzzling to find a good spot for them. I managed to stick them to the side, under a plateau and on the outside of a drawer with three of them. But the freezer in the shed is so tight that i had to lay in in one of the drawers.
I have tried that. That makes the top bar even more large. The problem i have is that the info gets on top of each other and it doesn’t help to zoom out the browser
If you dare, you could play with the font size and icons size in the code. That shouldn’t be too difficult.
Most or all of that code is in the web.css and the homey.ink.color.css files.
I like you’re dashboard PetervdK. Is it possible that you can share this with me or us.
I never actually used the web or ipad theme in a portrait orientation, the iphone theme is portrait orientated by design, can your try that one?
Sure. Here you can download the zip file.
It’s a complete copy so you can adjust everything to your own needs.
Next thing i will try to establish is to display the last time the device has reported when you click on a device tile. I am able to extract the date and time already. But since my code is based on an early version without tile clicking capability, i have to cut/paste/adjust the new code from @DaneedeKruyff to establish that… Gonna take some time i am afraid… :slight_smile: :stuck_out_tongue:
Thank i will try the zip!
in app/themes/ you can change font size in the theme you are using
If you are using theme=web then you can change the values in web.css:
#text-large {
font-size: 6vh;
margin-top: 1vh;
font-weight: 250;
#text-large:after {
font-weight: 300;
width: 10vw;
margin: 2vh auto;
#text-small {
font-size: 3vh;
font-weight: 250;
As for the date description it’s also a translation issue. Right now it says “den 21a maj” but the correct way would be just “21 maj”. Didn’t purpose that change to @DaneedeKruyff though since I thought it’s a minor issue…
