Homey 2.0.0 Community App Compatibility List
Apps not possible to install:
Itunes: https://apps.athom.com/app/com.apple.itunes
Kodi: https://apps.athom.com/app/nl.marvinschenkel.kodi
Led Ring Collection: https://apps.athom.com/app/openmindnl.ledcollection
Smart Presence: https://apps.athom.com/app/nl.terryhendrix.smartpresence
Homey Dash: https://apps.athom.com/app/com.swttt.homeydash
Ring: https://apps.athom.com/app/com.ring
FlowBackup: https://apps.athom.com/app/nl.regoor.flowbackup
Heimdall: https://apps.athom.com/app/com.uc.heimdall
Candy: https://apps.athom.com/app/info.matjaz.candy
Philio: https://apps.athom.com/app/com.philio
Google Maps: https://apps.athom.com/app/com.google.maps.directions
TKB Home: https://apps.athom.com/app/com.tkbhome
Yamaha: https://apps.athom.com/app/martens.yamaha
Be Bext: https://apps.athom.com/app/eu.benext
PowerShell CLI: https://apps.athom.com/app/nu.dijker.homeypscli
I can confirm that https://apps.athom.com/app/com.jreenen.homeyharmonyhub is working on firmware 2
Good Job @jreenen !!!
You can add:
Philips Hue https://apps.athom.com/app/nl.philips.hue
to the list
It does not install on v2.
(and while installed it did not work either)
“The evohome doesn’t work as it should. I can read the temperature but can’t adjust it.”
Same here, read = OK; write = doesn’t work.
Hi Jeroen.
I’ve added the windmeter in V2.0; RC9.
Unfortunately, no readings.
Br,
There are still issues with BLE on v2.0-rc9
Need to ask at this point: are all devices surely tested?
I am not able to pair body motion sensors and vibration sensors :confounded:
Yes, these devices work.
If you read the forum topic of the app, you’ll see that best practice is to keep the device awake once you activated the inclusion mode, by keep pressing the button every 1-2 seconds.
Is it right and known that all apps that are using Bluetooth not working currently? Tried beacon, MI flora and the mipow app. None of them are working…
Correct! And like Ted also says: they work.
Yeah, read it and did so. Though there’s written it isn’t required for the Aqara sensor :man_shrugging: :thinking:
Still trying - okay:
Deinstalled app,
Reinstalled app.
Reboot Homey.
Tried again - really hard.
No chance to add them sensors :thinking:
I put in a support ticket asking if anyone was working on the BLE as reported by koktai and the reply said they are getting V2 stable first.
Debatable if getting BLE working is part of getting V2 stable lol
Any information on the Homeyduino app?
hue app works without any problems
I’m talking about the Philips hue app that:
“This app adds support for all Philips Hue lights that work with the Philips Hue Bridge.”
I tried again to install it and now it does install on Homey.
So then I try to make it work in a flow by adding a card “Philips Hue, switch on all light in a room” then ‘choose an item’ then it says ‘No Results’. (in bridge I have a number of room defined)
So, that means I can not use the app Philips Hue (the bridge one) in Homey.
I have the homeyduino app installed and I can use it. (haven’t tried to install it, I installed it in 1,5)
So I haven’t fully investigated it.
You can not install it?
Let’s plz keep the conversation about community apps. The Hue app with the bridge and Homeyduino app are Athom apps. If they are not working like they should plz find the correct topic on the forum or make an issue at the correct place.
I have not yet updated my Homey, and the reason is mostly because I don’t know if Homeyduino works, that is a dealbreaker since I don’t know if the app will be further developed.
You don’t experience any problems? Adding new devices works? What kind of sensors do you use with Homeyduino?
Ha! I read “Community App Compatibility List” as that this a list made by the community about app compatibility for Homey 2.0
But so now I know
