Strange - must be something funny with the app store @Stian_Royland. Thanks for trying
Will try again later👍
Is there some way in hdl system to control from a HDL DLP /SWITCH to a zwave relay in el. socket? I have a socket with coffemachine I will controll with my switch. Every time i activate switch, its active in 10 min. But I dont have any relay on it now.
@Stian_Royland I’m thinking that the next thing I’ll add is support for universal switches. That way, your DLP can set the universal switch and your flow in Homey can start because of that. BTW: New test version out now to fix so that your dimmer is actually added as a dimmer. I think you have to delete the one that was added as a relay. HDL SmartBus App for Homey | Homey
All working fine now. Thank you.
I see the outdoor sensor have humidity too, when you modify sensors with lux👍
It would be nice with universal switch as you mentions🙂
Lux is out on the Test version now
Universal switches is out in test now: HDL SmartBus App for Homey | Homey
Works somehow, i programmed a switch to send US 101 On to 1.195 (Homey HDL app) The HDL app recognices this but the HDL button flashes, so indicating that there is no reply from the device. Same as if you program a button to control a relay that not exsist, it only flashes.
I did a test from a DLP to Logic module. DLP Sends US 120 On to Logic module 1.20.
DLP 1.101 button: 1 1 20 Universal Switch 120(Switch no.) ON(Switch Status) N/A N/A
Bus data related:
00001 2020/04/13 09:50:48:588 10 01 65 00 A7 E0 1C 01 14 78 FF 00 00 09 F5 E7 Universal Switch Switch No.-120; ON 1-101-HDL-MPL8.48-1etg Stue Trapp—> 1-20-Logikk modul
00002 2020/04/13 09:50:48:648 0D 01 14 04 55 E0 1D FF FF 78 01 AC 80
00003 2020/04/13 09:50:51:136 10 01 65 00 A7 E0 1C 01 14 78 00 00 00 09 BE 44 Universal Switch Switch No.-120; OFF 1-101-HDL-MPL8.48-1etg Stue Trapp—> 1-20-Logikk modul
00004 2020/04/13 09:50:51:173 0D 01 14 04 55 E0 1D FF FF 78 00 BC A1
00005 2020/04/13 09:51:00:445 11 01 14 04 55 DA 44 FF FF 14 04 0D 09 33 00 1B BF Broadcast system date and time(every minute) 1-20-SB-DN-Logic960-Logikk modul
Is support for DMX dimmer possible? Is acts like a normal dimmer with 48ch. What is does is translate to DMX signals. Model: SB-DN-48DMX Fw: HDL_MIRACLE_2010/07/01
