This week I’ve noticed that the geofencing option is not working correctly at the moment. I’m not quite sure if this is a Homey problem or a iOS problem.
Problem descrption
I’ve set a Homey Flow to turn on the lights when my wife or I will arrive at home, no matter what time it is after sunset. This has been working very well, untill now.
In the Homey Timeline I can see that my wife and I are at home in the evening. When we go to sleep, we turn off the light manually (via a Heat-it Zwave controller). The following morning I see that the lights are (still) turned on. When I look into the timeline, I can see that my wife has no presence at home for a few seconds. The Homey sees this as a homecoming, and will therefore turn on the lights.
First I thought this might be a problem of my wife’s phone. But last night I had the same issue, due to the geofencing option on my phone. As you can see in the screenshot (sorry, it’s in Dutch), we’ve been ‘away’ for only a few seconds.
Problem solution
It’s not necessary to leave the lights on just for the cat, so I want to solve this problem. Possibly this is a problem regarding the Homey software or iOS. But I don’t want to be dependent on these platforms (at least regarding this problem).
Is there an option to check what the time is between homeleaving and homecoming? In that way we can just check if the time between those actions was more than 60 minutes for example. I did a quick search for an solution like this, but I couldn’t find anything useful.
Deeper problem solution
Sometimes we see that it’s not ‘homeleaving’ and a few seconds later ‘homecoming’. In that case it appears that the Homey platofrm doesn’t register a homecoming at all (see as well the screenshot). I see this as another issue, but still the geofencing issue.
Does anyone has the same issues?
Could anyone help me solving this issue?
Thanks,
Niels
